Old 08-26-2010, 12:27 AM   #1
Mike Quillici
Master Cylinder Bad?
I went to replace my front brake hoses today, and as soon as I disconnected the passenger side brake hose, fluid began running out of the steel brake line. It continued to run until it drained the front reservoir of the master cylinder completely. I don't know for sure, but I wouldn't think that this should have happened.
Please advise!
1972 Chevy C-10 ~ 188,000 miles give or take
Mike Quillici is offline   Reply With Quote
Old 08-26-2010, 12:43 AM   #2
hotrod100
hotrod100's Avatar
Re: Master Cylinder Bad?
Nothing unusual with this. Perfectly normal.
My build thread.
hotrod100 is offline   Reply With Quote
Old 08-26-2010, 12:52 AM   #3
Mike Quillici
Phew. Good to know.
Old 08-26-2010, 01:15 AM   #4
Mike Quillici
On another note. I think my proportioning valve is sticking. Occasionally, the brake light comes on, and won't go off until I hit the brakes hard. I usually hear something click when that happens. Is there anything that I can do to fix this, other than replacing the proportioning valve?
Old 08-26-2010, 07:51 AM   #5
cdowns
cdowns's Avatar
have you pulled off the rear drums and checked for indications of leaking wheel cylinders???
Old 08-26-2010, 11:39 AM   #6
Mike Quillici
Negative. Not yet. Could that cause the proportioning valve to stick?
Old 08-26-2010, 12:04 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
It may be that the "188,000 miles, give or take" caused the proportioning valve to go bad.
Member Nr. 2770
Old 08-26-2010, 12:07 PM   #8
Mike Quillici
That's kinda what I was thinking. It doesn't look like regular auto parts stores sell them either. . .and at LMC they're quite pricey.
Old 08-26-2010, 08:10 PM   #9
Mike Quillici
Incidentally, what the heck size wrench fits the compression fitting between the brake hose and the brake line???
