Old 08-26-2010, 12:57 AM   #1
jason7698
Tire rub need advice!
I just put new wheels and tires on I went with a 295/45/20 in the rear and now it rubs and I cannot take the tires back so I need to know my options? I have a leaf spring rearend that has been lowered...Thanks
jason7698 is offline   Reply With Quote
Old 08-26-2010, 05:56 AM   #2
cdowns
cdowns's Avatar
Re: Tire rub need advice!
for a solution figure out where it rubs then either move tire away from whats rubbin or move whats bein rubbed away from the tire that's rubbin it
Old 08-26-2010, 09:38 AM   #3
Lee H
Lee H's Avatar
What's rubbing? Pics.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 08-26-2010, 11:20 AM   #4
big_al_71
big_al_71's Avatar
Get an adjustable pangard bar and center the differential. I have 295/45/20's in the rear and they are close but no rubbing...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-26-2010, 11:35 AM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Umm.... he said he has leaf springs... no panhard bar. LOL
My guess is the wrong offset of wheels. Need more info on where it is rubbing. Fender lip, frame, ??? Pics would help too.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-26-2010, 01:21 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Can't get much simpler than that!!
Jason, pics would help us... we can't see the problem from here.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 08-26-2010, 01:37 PM   #7
jason7698
They are rubbing on the outside of the inner fender well I was thinking of making a spacer to go between the leaf springs or grinding some of the inner well out?
Old 08-26-2010, 03:46 PM   #8
Lee H
Lee H's Avatar
Both sides rubbing?
Old 08-26-2010, 03:58 PM   #9
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
place a broom handle on the tire between the tire and body then roll the truck forward it will roll the inner in a bit..you may have to do it couple times
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 08-26-2010, 04:56 PM   #10
raycow
Wheels and tires are expensive. Lifting the truck is cheap. That should tell you what I would do.
Ray
raycow is offline   Reply With Quote
