Old 08-26-2010, 06:25 AM   #1
67C10BUB
67C10BUB's Avatar
Which wiring harness to get
I would like to rewire my entire truck. The PO really made a mess of things and I think it would be best to just start over. I was thinking about the Painless one, but I thought there may be others that people have used that are better. Anyone have an opinion?
67C10BUB is offline   Reply With Quote
Old 08-26-2010, 08:50 AM   #2
evilways
evilways's Avatar
Re: Which wiring harness to get
I have the EZ wire in my truck, only complaint is some of the terminals in the fuse panel came out while installing it correctly, the PO just threw it in with a crap ton of electrical tape. So I started all over using the same harness, although I used crimp terminals and glued heat shrink so not a possibility of any corrosion ever... That being said the terminals that came loose could very well have been due to the hastily install the PO did, so I guess I can’t really blame the brand, other than that I like it, all wires labeled with plenty of accessories if need be. I would check all terminals prior to install just to make sure nothing pops out after you got it all tucked away neatly.
Mark
1967 C/10 stepside lwb daily driver
1968 C/10 fleetside lwb parts truck
1971 Cheyenne Super swb project
evilways is offline   Reply With Quote
Old 08-26-2010, 08:55 AM   #3
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
American Auto Wire...period
Tom Vogel is offline   Reply With Quote
Old 08-26-2010, 09:49 AM   #4
'70_402
'70_402's Avatar
i got the painless kit and it was awesome...... truly awesome...
'70_402 is offline   Reply With Quote
Old 08-26-2010, 02:01 PM   #5
67C10BUB
67C10BUB's Avatar
Thanks for the info. The EZ wire has a good price, but it looks like a generic harness. The American Auto one looks like it has everything, but is almost $600. The painless one looks like it has most everything, is a custom fit for my truck, and is under $400.
Old 08-26-2010, 02:34 PM   #6
67C10BUB
67C10BUB's Avatar
I just found a company called Rebel wiring. They offer an EFI 20 circuit harness. Since I am in the process of putting a 2008 Silverado 5.3 in I think that maybe this is the way to go. Anyone tried this one?
Old 08-26-2010, 04:33 PM   #7
'70_402
'70_402's Avatar
http://ksu.craigslist.org/pts/1879062025.html
Old 08-26-2010, 05:06 PM   #8
tubbedII
needs more $$$
tubbedII's Avatar
Can't help with the Rebel, but I put a painless kit into my Blazer, and would go with either the same kit or an EZ wire kit if I ever had to do it again. IIRC, the painless had some extra wires for EFI...didn't pay attention to them much since I didn't need them, but I know for sure it has a wire for a fuel pump in the tail area.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 08-26-2010, 07:11 PM   #9
tonypaul
tonypaul's Avatar
I got one just like this: http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
I havnt installed it yet, but it looks really nice. I have only done 3 complete wiring harness' before, but this it the cheapest and the nicest looking one I have ever bought.
tonypaul is offline   Reply With Quote
Old 08-26-2010, 08:05 PM   #10
67C10BUB
67C10BUB's Avatar
I believe this is the EZ one. I think I want the colored wires. Seems like a good price though.
Old 08-26-2010, 09:03 PM   #11
tonypaul
tonypaul's Avatar
Yes its the EZ wiring harness, all my wires are colored it just has the black protective mesh on it. I thought it might look better on my truck. The same vendor has the regular wiring harness as well for the same amount.
Old 08-26-2010, 09:16 PM   #12
71 super
71 super's Avatar
Unless you are adding a computer controlled engine, power everything etc. M&H or American Auto Wire are very very nice plug and play STOCK harnesses, they do offer units that upgrade to hei. I have used both brands and have had zero problems, all connections were already made with as- original terminals. The painful and other similar kits require that you crimp all connections and you will need a stock harness to pull special terminals off of (you reuse old stuff). The wires are labelled and you can custom route everything, but you are looking at several days with a schematic or a couple of hours and be ready to go.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 08-26-2010, 10:25 PM   #13
leddzepp
Moderator
leddzepp's Avatar
x 2.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-27-2010, 12:58 AM   #14
67C10BUB
67C10BUB's Avatar
I am thinking that I will just go with the EZ Wiring setup. It is the cheapest and seems like it is going to work with my EFI setup.
Old 08-27-2010, 09:40 PM   #15
gcburdic
Restoration Virgin!
gcburdic's Avatar
Check this out guys....If you want that AAW harness....mbgmike has a great group buy price....http://67-72chevytrucks.com/vboard/s...d.php?t=418468 looks like $100+ discount!!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 08-28-2010, 12:33 AM   #16
67C10BUB
67C10BUB's Avatar
Thanks for the heads up. I don't know how I missed this.
Old 08-28-2010, 03:19 PM   #17
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I am in the middle of doing an ez wire install and its very nice ......Not as nice as my painless however..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-28-2010, 04:06 PM   #18
Shane
Shane's Avatar
i've either installed or help install both the painless and the ez wiring harnesses. just personal opinion here, but the painless harness is not "more nice" enough to justify the much higher price.
for what it's worth, I have a universal 24 circuit EZ Wiring harness in my current truck project.
Shane is offline   Reply With Quote
