08-26-2010, 06:52 AM | #1 |
UCA63
Anyone split thier trailing arms ?
To clean up in between and then bolt or weld them back together ?
Mine are in pretty good shape but where there isn't rivets I can slip a putty knife into and can see grit and dirt (probably rust) in there. I did a search but didn't come up with much Thanks for the help T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
08-27-2010, 01:23 AM | #2 |
Re: Anyone split thier trailing arms ?
Low $ approach: clean yours up, sandblast, then weld on reinforcing plates, like ECE's kit. Easy project if you have a welder.
http://www.classictrucks.com/tech/07...kit/index.html More $$: buy new tubular trailing arms.
292 + TKO500 |
08-27-2010, 12:16 PM | #3 |
UCA63
Thanks heater
They're in great shape. I was mostly concerned with just getting all the crap out from in between them,and getting some rust protection in there. T
08-28-2010, 12:19 AM | #4 |
60-66 Nut
If it's just the rust issue, I would just clean them the best you can and then brush some POR15 in that seam really heavy so it runs between the halves. Do this from both sides, and it should seal that area up from further rusting. Another option would be to weld that seam up continous. You would want to do it in steps and alternate from side to side to minimize warpage.
08-28-2010, 06:27 AM | #5 |
UCA63
Thanks Cpt
If I don't split them (which I probably won't after looking at ALL THOSE RIVETS yesterday) that's the plan,load 'em up I don't think I need to stitch them though. Lots of talk on here about how weak they are,I've looked at a lot of these trucks over the years and I've never seen a collapsed one,beaten and bruised, yes,bent up and non usable,no. All I can think when I hear that stuff is that the farmers son (or nephew,etc) decided he would attempt some Dukes of Hazzard stunts with the old girl T
08-28-2010, 11:27 AM | #6 |
Hollister, CA.
I too have run a contiuous bead along a set years ago for a customer with a 65 .... (long b4 I was into these trucks)
His driver-side TA actually let go at the front bushing location. So we cleaned then up, and welded up the seams. I noticed on my C-20 arms, they have a longer reinforcement plate rivoted under the spring (as compared to the C-10)...
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
08-28-2010, 01:08 PM | #7 |
Yes, if you have any available, the C-20 arms are a worthwhile easy upgrade for a C-10.
Ray |
08-29-2010, 05:33 AM | #8 |
UCA63
Cool,I didn't know they were different
Everything around here seems to be 1/2 ton or 1 ton T
