Old 08-26-2010, 08:54 AM   #1
LeatherMan69
Best gas tank to use
Im looking to change out my gas tank like many of you already have. Problem Is i dont really know what characteristics to look for, or what is going to be the best fit. Im not going crazy on the lowering of my truck so i dont think clearence from the ground will be an issue. You guys have any suggestions on the best gas tank to use. Hoping to get a used something or other... Plus where would i find these things at?! junk yard, Ebay?
thanks fellas
LeatherMan69 is offline   Reply With Quote
Old 08-26-2010, 12:19 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Best gas tank to use
It seems that a lot of people go with a tank from a Blazer if you are not worried about clearance.
I have heard that the position of the cross member in the back will have to be changed and of course the spare tire mount will no longer be used.
I personally like the tank in the cab as long as it does not leak and there isn't any gasoline fumes.
Of course if you are looking for better traction a tank in the rear will help.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-26-2010, 02:59 PM   #3
LeatherMan69
Are the Blazer tanks pretty easy to find/ cheap?
Old 08-26-2010, 03:50 PM   #4
barry h.
barry h.'s Avatar
What year blazer work the best
barry h. is offline   Reply With Quote
