Old 08-26-2010, 04:04 PM   #1
ubtripn
ubtripn's Avatar
I should have listened to myself!?!@?!?
So as some may know, I was leaking oil out of an intake bolt on my 68's 350. I was pulling each bolt out and applying high temp Permutex when one twisted off. I started it up and it didn't leak oil and it didn't mix any oil with the antifeeze or vice versa so I thought - I should just drive it and watch it closely. The prevaling opinion though was that I should tear it apart, remove the stud and install new gaskets because if I don't the intake manifold could eventually warp or worse I could lose the engine. So I finally decided to do it and took my time over the past couple of days doing the work. Everything went SO SMOOTH. This morning I finished the work and started the truck to let it warm up so I could re-torque the bolts, etc.. I am in the garage 10 feet away as it idles and got a little side tracked cleaning my tools, when I walked back out there was anti-freeze everywhere. A hose blew off and I didn't hear it. When I first started it, I inspected it closely and all was well but it must have blew right when I stepped into the garage where the stereo was on. Anyway, I shut it down right away and let it cool then refilled the radiator, started it up and hooray!!!! - Oil in the radiator that looks like coffee mixed with milk!!! I am so angry right now, I cooked the engine and it is my fault, it's just that if I had let it be I would have a running truck right now. It is all my fault - I didn't fully seat the hose apparently. I am tossing the entire engine and putting a new one in after I save up the money. I just knew something was going to happen but didn't trust my gut. Don't you hate it when that happens.
Oh well, I want to thank everybody for the help they have given me along the way. Just one more - "had to learn the hard way" lesson for me.
ubtripn is offline   Reply With Quote
Old 08-26-2010, 04:21 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: I should have listened to myself!?!@?!?
Hard lesson to learn.....
Hope you get it back running....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 08-26-2010, 05:26 PM   #3
haysonj
haysonj's Avatar
I wouldn't be so quick to throw in the towel as it could just be a blown gasket or something simple. I had water in my oil and all I did was re torque the heads and change the oil and all was good. Do some investigating first.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-26-2010, 06:10 PM   #4
Tkmadone
You did the right thing by fixing a known problem. The subsequent issue was a mistake anyone could have made. If you hadn't fixed the broken bolt it could have stranded you somewhere awful or something else may have happened. It does no good to second guess things like that. Chalk it up to a tough lesson and keep doing it the right way and eventually it will work out just fine.
Tkmadone is offline   Reply With Quote
Old 08-26-2010, 06:42 PM   #5
ubtripn
ubtripn's Avatar
Thanks guys, your right and I have cooled down a bit now. I am hoping it just damaged the head gasket. If so I will just go back in and fix it.
Old 08-26-2010, 07:19 PM   #6
pat 70/71
pat 70/71's Avatar
sorry to here that happened to yah. some of the best lessons in life are reinforced by physical pain or financial hardship. My dad used to tell me that all the time when I was just a little nipper. I'm sure you will be happy in the long run. cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 08-26-2010, 07:28 PM   #7
OrrieG
OrrieG's Avatar
Took me a while to learn that lesson too, youthful impatience. I now have the sign in the shop "If you don't have time to do it right, where are you going to get the time to do it over?" were I can see it all the time. Be glad it did not happen at 75 mph and hydro locked the engine or worse.
OrrieG is offline   Reply With Quote
Old 08-26-2010, 07:35 PM   #8
ubtripn
ubtripn's Avatar
See that's the thing though, I took my time and focused on doing everything right, I just didn't push the bottom hose far enough and cannot figure out how I missed it. Oh well, I will never miss it again =)
Old 08-26-2010, 09:13 PM   #9
Sammy
Fix what caused the oil n antifreeze problem. Drain that oil with some of the cheapest oil you can get at the store. Refill everything give it another chance let it run for an hour or two if the oil n water don't mix. Drain the oil, change drain the filter and take a chance keeping an eye on the oil pressure and water. Drive it that way for a week and if it's good you have saved a engine change. You might get by without any further problems. All depends on the amount and how much water got in the pan.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-27-2010, 11:17 AM   #10
ubtripn
ubtripn's Avatar
Thanks friend, I am going to do just that.
Old 08-27-2010, 11:56 AM   #11
70STOVEBOLT
70STOVEBOLT's Avatar
What does the oil in the pan look like? Was there only oil in the water, or both ways? If the oil in pan looks the same as the water in the radiator, I would not run it, you will only do more damage. It doesn't take much antifreeze in the oil to cause a spun bearing. As it is now, the engine may be able to be saved by replacing the head gaskets, but if you spin a bearing, it will be time for another engine or a major overhaul on that one. Just my $.02
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 08-27-2010, 12:39 PM   #12
ubtripn
ubtripn's Avatar
Thx for the advice, I drained the oil and it looks clean. There was only a bit of film by the rad cap when I found it, since then I flushed the anti-freeze and cannot see any more oil.
Old 08-27-2010, 12:41 PM   #13
ubtripn
ubtripn's Avatar
I think I am going to put in new oil and filter along with some new anti-freeze and see if it recontaminates.
Old 08-27-2010, 01:01 PM   #14
70STOVEBOLT
It should be fine, just keep an eye on the oil pressure and the water temperature when you run it.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 08-27-2010, 05:16 PM   #15
ubtripn
ubtripn's Avatar
Will do, thanks.
