Old 08-26-2010, 10:32 PM   #1
ah_5500
the pinion shims shakes
ive done alittle searching and cant seem to find pinion shims for my 67 coil spring pick up. thanks
ah_5500 is offline   Reply With Quote
Old 08-27-2010, 02:22 AM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: the pinion shims shakes
CPP has them in 1-4deg. Not sure if anyone else has them, but if you order through CPP be sure to call Jeff and tell him you're a member here.
http://www.classicperform.com/Store/...k/6072RPS1.htm
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 08-27-2010, 05:05 AM   #3
dznucks
dznucks's Avatar
yes, cpp is one of the only places that carries them. you can go online and find people that make shims (for 4x4 and racers), but the price is about the same.
i am running 2" drop blocks, so i had a buddy machine the right angle on the block
if you do find a place that carries them cheaper than CPP, please post that vendor on the site.
dznucks is offline   Reply With Quote
Old 08-27-2010, 12:14 PM   #4
usmcchevy
usmcchevy's Avatar
Just an idea, could you take normal pinion shims, cut the bolt hole slots and make them work? Shim might be a bit small, but might work.
http://www.summitracing.com/parts/SUM-770025/
Build thread
LSx Swap FAQ index
Old 08-27-2010, 07:38 PM   #5
ah_5500
next question is that what would be the best way to find the degree i need. its lowered 7 inches in the rear...go straight to the 4 degree?
Old 08-30-2010, 06:54 PM   #6
ah_5500
bump
Old 08-31-2010, 08:17 AM   #7
68Stepbed
68Stepbed's Avatar
The best thing to do is take it to a driveline shop and have them tell you what angle you need. I don't know of any right off hand. I do remember seeing an ad on the counter at Performance Products. Give them a call and see who they recommend. 865-689-4700
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 08-31-2010, 09:44 AM   #8
dznucks
dznucks's Avatar
No dont guess the angle. Google the topic. Thats how i taught myself how to do it. you will need an angle finder. its pretty simple to do.
Here is an angle finder at home depot for $8......
http://www.homedepot.com/webapp/wcs/...367&marketID=3
If your angle is off, it can cause driveline vibration and it makes it easier to snap the ujoint when you really get on it.
Old 08-31-2010, 12:17 PM   #9
ah_5500
ok. thanks guys
Old 08-31-2010, 12:53 PM   #10
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
This is the guy you want to talk to in the post, wont cost an arm or leg either. The shims he makes are smooth. Also, I got a small digital angle meter from harbor Freight that worked perfectly. Read the post.
http://67-72chevytrucks.com/vboard/s...d.php?t=417888
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 08-31-2010, 02:19 PM   #11
dznucks
dznucks's Avatar
Thats actually the same perosn i found online that i almost bought my shims from. I think he quoted me $40-50 for the set.
I ended up having my drop blocks machined to the angle i needed for $20.
When you lower the truck, you throw off the pinion angle. If your running a bagged truck you need to set the pinion angle at your ride height, and understand that your going to throw you angle off when you raise or lower the vehicle.
thanks, smitty, for posting that up for everyone else that runs into this.
Old 08-31-2010, 07:27 PM   #12
71meangreenc10
My 4 degree ones were 15 each.
Smitty
71 C30 Wrecker
