Whats The Difference Resistor?
I just got my new Heater Blower Motor Resistor from the Truck Shop. I have factory air. There are two resistors available one with air and one not. I am not sure they sent the proper one. How can I tell from the two witch one is with air and on that is not??
Redefining LowBudget
Re: Whats The Difference Resistor?
pull ypour glove box and look??? its tucked in on the side of the air box against the wall
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
do a search for wiring diagrams for our trucks..I had it marked but the putr it was on crashed so I can't find it quickly for yea .....then you can wire to the correct colors....
I got mine at autozone if I remeber correctly it has 5/6 wires to it |
The non-AC and the AC resistors are very different. The non-AC resistor will not fit in the AC resistor mounting plate. The non-AC resistor has a longer mounting plate then the AC resistor.
If the resistor you have fits then it should be the right one. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
#7 | |
