Old 08-27-2010, 02:37 PM   #1
AK4Life
AK4Life's Avatar
Body Mounts
LMC kit or energy suspension?
AK4Life is offline   Reply With Quote
Old 08-27-2010, 08:03 PM   #2
SOON2BLAZE
SOON2BLAZE's Avatar
Re: Body Mounts
Hold on let me get a drink, this will be interesting.... Some like rubber, some like poly. I likey poly.
SOON2BLAZE is offline   Reply With Quote
Old 08-27-2010, 11:51 PM   #3
69-72
69-72's Avatar
Re: Body Mounts
I am all for rubber but my LMC kit started cracking pretty bad after a year.
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 08-28-2010, 12:06 AM   #4
TonyJohnson
TonyJohnson's Avatar
Re: Body Mounts
Got the rubber set from mbgmike. Nice...
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 08-28-2010, 08:44 PM   #5
AK4Life
AK4Life's Avatar
Re: Body Mounts
What poly kit did you purchase and from where?
Old 08-31-2010, 12:37 AM   #6
trz1000
Re: Body Mounts
Here's the Energy Suspension poly kit I used
http://www.summitracing.com/parts/ENS-3-4110G/
You will also need to buy assembly lube (use it or you'll have squeaks) and bolts. I had to do some shimming to during the install to make everything sit right. Got the shims from McMaster-Carr. 3"x3" stainless shim with tab. They're available in various thicknesses.
trz1000 is offline   Reply With Quote
Old 09-01-2010, 11:44 AM   #7
SOON2BLAZE
SOON2BLAZE's Avatar
Re: Body Mounts
^ Same kit here
Old 09-02-2010, 09:18 AM   #8
AK4Life
AK4Life's Avatar
Re: Body Mounts
Thanks for your replies and advice. Think I will go with the energy suspension poly kit.
Old 09-30-2010, 07:31 PM   #9
AK4Life
AK4Life's Avatar
Re: Body Mounts
Ok. Been searching for an hour for this post I came across about 3 months ago. It may have been a build but the guy had pics of the body mounts and bolt/nuts used along with the grade.
I need the lengths of body mount bolts for each position and the grade of steel.
Old 09-30-2010, 08:52 PM   #10
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Body Mounts
Not really an exact answer to the last question... but an easy (not cheap) solution...
ORD: Off Road Design has a 1" body lift kit that comes with the correct extended length bolts. I will probably go poly with the 1" kit so I dont have to search for washers and bolts....
Grade 8 would be overkill so probably grade 5...
http://www.offroaddesign.com/catalog/oneinchlift.htm
Rich
1972 K5 Blazer CST Click HERE
Old 09-30-2010, 09:28 PM   #11
trz1000
Re: Body Mounts
http://67-72chevytrucks.com/vboard/s...ht=body+mounts
Old 10-01-2010, 05:24 PM   #12
AK4Life
AK4Life's Avatar
Re: Body Mounts
Thank you trz, just the post I was looking for
