Old 08-27-2010, 03:18 PM   #1
72gmcshorty
72gmcshorty's Avatar
Swap to carb?
I've got this 5.3lt motor out of a 2006 truck. I have the harness and the motor and accessories. What is the rough cost to switch to a carb setup vs FI? What is involved in changing over to carb? What about fuel pump wise?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 08-27-2010, 04:14 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Swap to carb?
from what I understand, the carb/intake will run you around $600.00 I am not sure about fuel delivery for carbed but the pump for FI will be around $100.00 along with a filter, external pump. motor mounts with adapter plates around 150.00 what trans are you thinking? either way if it isnt the stock 2006 4l60e you will need an adapter flywheel or bushings. 100.00 or so
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-27-2010, 04:25 PM   #3
LEEVON
Moderator
LEEVON's Avatar
Re: Swap to carb?
1) MSD 6010 $300
2) GMPP or Edelbrock Victor LS1 carb intake $280
3) Carb approx $300
4) Fuel pump, generic 6-7psi electric $100
5) Sell your Intake, Harness and ECM ($250)
The MSD is very, very easy to hook up but you don't want the Edelbrock version. You set the timing curve with your laptop on the MSD, can't do that on the Edelbrock. These engines make for very clean carb installs and gain a few HP. I'm doing one but it's just for looks, I want it took look old so I'm also dumping a couple hundred on some finned valve covers and relocating the coil packs.
Lots of opinions out there about switching from EFI to carb. My personal opinion is do what you want, it's still far cheaper to get 300+ hp out of a $500 LSx engine plus the above parts than to build an old school, solid lifter carbed small block that will soon leak so why not?
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 08-27-2010, 06:25 PM   #4
72gmcshorty
Re: Swap to carb?
Thanks for the answers, i'm trying to decide which route will be easier/cheaper in the long run. I am in Canada and don't have the luxury of easily returning parts and pieces that don't fit. I also don't have a trans yet. Nor do i have a cheap donor vehicle (junkyards here act like their vehicles are made of gold, pricewise)...
1992 Gmc 2wd
Old 08-27-2010, 06:33 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Swap to carb?
efi to carb swaps... are getting as easy as carb to efi swaps.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-27-2010, 08:03 PM   #6
85burb
85burb's Avatar
Re: Swap to carb?
In my opinion it is much simpler to put carb on then jack around with all the wires that need to be hooked up everyware with the efi. I am doing a 6.0 carb swap right now. Depending on what fuel system you get and other addons you may want they are both about same price.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
