I feel stupid asking this but... how do i get the dip stick sleeve out? I broke part of it off and need to get the rest off to replace it.
Thanks |
Old member
Mine has a 7/16" bolt right under the manifold into the side of the blaock. After taking it out it's a matter of pulling it out. It's a tappered fit into the block on mine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Dip Stick
i just use visegrips and yank or hit them to remove from block
Re: Dip Stick
if its broke off flush your options are pretty limited. i'd try to screw in a bolt or a tap to get a bite on it and pull it straight out. careful with a tap, if you bend it very much it will snap off in there and things just went from bad to worse. if its still got some sticking out some good ol vise grips should do the trick.
Re: Dip Stick
If you can't grab it with vise grips try bending it in a little with a small screw driver or chisel, lightly tap toward center and try grabing it with needle nose.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Re: Dip Stick
GOT IT thanks guys
71 ![]() |
