Old 02-23-2003, 08:42 PM   #1
BraveDave
Aligment Specs for a "72
Believe it or not, I came home a couple of weeks ago and my dog had shredded my '72 shop manual. I need the alignment specs to see if the tech at Firestone did my aligment correctly. It still looks to me that the tires are kicked in slightly at the top. This just doesn't look right to me. Thanks!
Brave Dave
'72 Chevy Cheyenne Super, '56 Chevy Bel Air,'56 Chevy Nomad, '61 Chevy Impala, '64 Cadillac Fleetwood, 1966 Thunderbird Convertible
BraveDave is offline   Reply With Quote
Old 02-23-2003, 08:57 PM   #2
72CustomCamper
Be careful with original specs..especially if you have the original front coil springs (sagged out after 31 years of supportin' your cool truck).
Any good alignment shop should be able to give you a zero camber without any original data.
'72 GMC C20, "2500 Super Custom", Custom Camper, New 454
'93 K2500 Suburban, Old 454 (157K)
72CustomCamper is offline   Reply With Quote
Old 02-23-2003, 11:11 PM   #3
BraveDave
i have 1-1/2 inch dropped springs on my truck. he set the camber at -0.4 deg. i would have thought 0 deg. would be correct. the tires should be straight up at standing still. is this right?
Old 02-24-2003, 12:37 PM   #4
72CustomCamper
Do you also have different wheels? The wider the tire is, the more important the zero camber is. The negative camber is good for vehicles designed for heavy cornering but over time it will wear the inside of your tire.
I would insist on a zero camber...
Old 02-24-2003, 02:57 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Maybe this will help...
When I lowered my '69, I had a set of 15x8's, all around. With the conversion to discs on the front, the front track width was increased by about 2-inches. I had to go to a pair of 15x7's, before I could get it aligned. Since we had put on new springs, dropped spindles (2-inches) and replaced the upper/lower control arm shafts and bushings, as well as all 4 ball joints, AND the tie rod ends, pitman arm and idler arm, we actually went back to the original settings for the '69.
The shop manual for '69, has a chart showing the caster and camber in degrees, for 10-30 series vehicles. For a C-10, it shows a camber of .75degrees. The caster is shown to be -1.0, at a curb height of 4.25-inches. This dimension labled as curb height is shown to be the space between the upper/lower control arms. So, weak springs will affect the measurement and therefore the actual adjustment.
Where I have my alignments done, I can request before/after computer print-outs, to settle my curiosity.
Member Nr. 2770
