brake light switch - pict request
I have a 72 C10, the brake light switch seems to be jimmy-rigged into place. I was hoping someone has a pict of what it's supposed to look like above the foot pedal. Thanks guys
Re: brake light switch - pict request
bump
Auto or man trans?
![]() Join Date: May 2009
Maybe this will help you out some.......
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
that pict slightly helps. Thank you.
Its a 4speed manual |
This is the best pic I can get from my '68, taken from the left side of the steering column, looking up. Maybe you can make sense of this.
It should have a plate with a hole in it to mount to. Put the threaded end through, put the nut on and adjust the 2 nuts to where the lights come on when brake depressed, go off when not.
ok its the same it appears... But the only problem is my brake pedal. The part that physically hits the switch, seems to be gone... -.-
ps. thank you for the pict GruntMoanCough
Trying to figure this out...is there a way to tell the difference on what side the wires go on! I.e. a "+" on either prong?
Asking because I'm finishing up my painless harness install... Posted via Mobile Device
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
Restoration Virgin!
check this thread for a close up picture...http://67-72chevytrucks.com/vboard/s...d.php?t=516224
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Thank you, Geoff!
#13 |
![]() Join Date: Nov 2012
does it matter what wire you hook up the ecm/tcm brake switch leads too? orange or white?
#14 |
![]() Join Date: Oct 2009
No, does not matter which terminal each wire connects to - switch is just a circuit interrupter. Pressing the pedal lets the switch pop open and close the circuit to light the lights.
Posted via Mobile Device |
