Old 08-28-2010, 05:05 PM   #1
Indyuke
Is this normal???
Been having a problem with pinging all summer long even though I'm running at 6 deg base timing on a low compression engine, so I popped my dist cap off to see what I could screw around with and found this. The fist two pics show worn(?) counterweights and the last pics shows what I'm used to seeing.
What do you guys think?
Indyuke is offline   Reply With Quote
Old 08-28-2010, 07:24 PM   #2
QKENUF4U
QKENUF4U's Avatar
Re: Is this normal???
looks to be made that way.... look in your first pic and you can see theres a notch in the other peice for the tab on the weight to slide into. never seen that myself.
as for pinging... welcome to crappy gas and hot temps... ya may have to step up the octane youre using....(87 to 92 ?)
QKENUF4U is offline   Reply With Quote
Old 08-28-2010, 09:46 PM   #3
Notrodder
Wow! That's pretty impressive wear. How's your truck run now?
Notrodder is offline   Reply With Quote
Old 08-29-2010, 09:36 AM   #4
grs
I believe the timing should 8 degrees.
grs is offline   Reply With Quote
Old 08-29-2010, 09:40 AM   #5
LONGHAIR
I have never seen weights worn like that.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-29-2010, 06:29 PM   #6
Indyuke
Just for the heck of it, I swapped in the dist from the last pic and am running base timing of 8 deg. Not a hint of pinging! It's from a '68 283, so even if both were in perfect condition, I'm sure the advance curve is slightly different between the two.
I'm going to try 12 deg advance tomorrow and see what that does.
