08-28-2010, 10:16 PM | #1 |
cluster opinions/options
I was able to pick up two clusters durring this week's autofair. I believe they are both from 80+ trucks. Im leaning towards using the tach cluster. My question here is about the next hurdle.. making it work in my '78. Ive done a little searching on the subject, but Im unclear as to what I have and where to go with it. 73-87's write up on the subject seems to say that any tach from a 78 and up should be plug and go. I was told the tach cluster was from an 85 model, so I should be ok there. However Ive also read some different writeups that involved repinning connectors, and changing the circuit on the back... What exactly do I need to do here to make sure I get this all wired up right? Wouldnt want to let any of the smoke out of the wires, now would we?
1978 Scottsdale - celebrating 10 years of teaching me profanity 1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold 1987 k5 blazer - sold... :\ seed money for the 81 1981 k20 4x4 - 5.3 swap in progress Events attended: Spring GOG 2011 Dale JR car show Summer 2012 Gathering at Tommys pickup parts |
08-28-2010, 11:23 PM | #2 |
Re: cluster opinions/options
i know that tach cluster is from '80 down. i think '76-80 because the battery gauge says volts. i could be off a year or 2. i'm sure someone else will jump in here and be of more help.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
08-28-2010, 11:48 PM | #3 |
Slugish
may be wrong , but dont think that is a 85 tach cluster . Its identical to mine , with like menace saying about the volts guage. Mine is a 78 or so & Its in my 84 . Did a 100 mph speedo even come in a 81 & up ? someone else needs to chime in here.
08-28-2010, 11:53 PM | #4 |
81 up was 85mph
08-29-2010, 12:08 AM | #5 |
What do we get for $10?
The tach cluster is not from an 85. The double warning lights at the bottom of the tach indicate it's a 77 to 79. If it has a mechanical oil gauge it is from a 77, if the oil gauge is electric it is from a 78 or 79. If the oil gauge is electric (and you already have gauges - not warning lights in your truck) it would plug and play in your 78. I notice it does have a newer style fuel gauge, but other than not matching visually it would work just fine.
The other non-tach cluster is from an 80 and up model truck. The newer style lettering (for lack of a better term) and 85 mph speedometer started in 1980.
1977 GMC K25 400/400/205 1989 Chevy Suburban R1500 350/700R4 (work beater) 1994 Chevy K3500 dually 454/4L80 1996 Corvette LT4 350/ZF 6 speed 2000 Bonneville SSEI Supercharged 3.8 Liter V6 1966 Chevelle 2 door sedan (Needs major repair ) Last edited by 77gmcjoe; 08-29-2010 at 12:22 AM. |
08-29-2010, 12:52 AM | #6 | |
CHEVY ONLY |
08-29-2010, 10:24 PM | #7 |
Thanks for the info. Couple more questions here. I didnt previously have the warning lights in my truck, just the hazard lights. Does that make a difference? And will it make a difference that the cluster seems to be from a 4 wheel drive? This cluster has the double warning lights. It also has a multicolor area starting at 4250. That would indicate a 78 or 79 tach, correct?
08-30-2010, 07:25 AM | #8 |
Getting Old; Going Broke
Your tach cluster appears 78, only difference I'm seeing is the fuel gauge not saying FUEL on it.
http://www.73-87.com/7387garage/inte...achometers.htm Good info in there.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
08-31-2010, 12:22 PM | #9 | |
1978 Scottsdale - celebrating 10 years of teaching me profanity 1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold 1987 k5 blazer - sold... :\ seed money for the 81 1981 k20 4x4 - 5.3 swap in progress Events attended: Spring GOG 2011 Dale JR car show Summer 2012 Gathering at Tommys pickup parts Last edited by xs-style; 08-31-2010 at 12:23 PM. |
08-31-2010, 05:32 PM | #10 | |
Still plays with trucks
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
08-31-2010, 05:50 PM | #11 |
Tach cluster is no older than '76 because the speedo has mph & kilometers on it
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB Last edited by BigRed76; 08-31-2010 at 05:51 PM. Reason: mispelled |
09-01-2010, 02:17 PM | #12 |
Found something that may be useful to anyone else doing a factory gauge swap.
http://www.rowand.net/shop/cars/1975...ingChanges.htm Down near the bottom of the page is a list of chevy and gmc part numbers. According to the list, the tach cluster is a 78-80 peice, which will work fine. Additionally the cluster above with the clock is a 81-87. Hope this helps someone else along the way.
09-01-2010, 02:58 PM | #13 |
1980 was the first year of the new style font with orange on it, and the lighter orange needles.
That is when the orange shift indicator needle started also.
CHEVY ONLY Last edited by joe231; 09-01-2010 at 03:01 PM. |
