Old 08-29-2010, 01:52 AM   #1
gloriavoxdei
gloriavoxdei's Avatar
Best towing cam for my '85 k30 454
I want to put a better cam in my '85 K30's 454 since the factory one in a tad aneimic. It has an edelbrock performer intake with a 750 cfm performer carb and the rest is original. The truck is used for towing and hauling only, let me know what you guys think.
1978 GMC Jimmy, 400, th350, np203 with part time conversion, Fibrecraft popup camper, soon to get a 14 bolt/d44 swap
2001 Yukon XL2500, 6.0, 4L85E, 4x4, family truckster
gloriavoxdei is offline   Reply With Quote
Old 08-29-2010, 06:12 AM   #2
BigBlocksRule
Re: Best towing cam for my '85 k30 454
Something in the 214/220 range should work fine.
BigBlocksRule is offline   Reply With Quote
Old 08-29-2010, 12:06 PM   #3
68 TT
Still plays with trucks
68 TT's Avatar
Call Comp Cams cam help line. They will be able to tell you exactly what will work best for your combination and use.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-29-2010, 01:11 PM   #4
BigBlocksRule
^ problem is that if you call Comp four different times, you'll get four different techs and four different recommendations.
Old 08-29-2010, 10:32 PM   #5
slugish
Slugish
x2
slugish is offline   Reply With Quote
Old 08-29-2010, 11:49 PM   #6
sierra4x4
sierra4x4's Avatar
The Comp Cams XE262h cam is an awsome cam for a fairly stock 454. Two of my friends run these cams in their 4x4's and they work great. They have a very good idle with a slight lope and make awsome power. My one buddy has it in a 80's 454 with peanut port heads and stock pistons and it produces very good power. My other buddy has it in a .060 over 454 with closed chamber heads with headers in a 72 4x4. His truck performs awsome. I highly recomend this cam.
sierra4x4 is offline   Reply With Quote
