08-29-2010, 10:17 AM | #1 |
c notch already in, want to move trailing arm crossmember back
im concerned.. i have already installed my c notch and welded it inside the frame rails.. my problem is after looking at other trucks i feel like teh rear end needs to be moved back some to the wheel will be centered in the wheel opening.. im pretty sure that after i move teh crossmember back the rear axle will not be centered in teh c notch.. I need any advive as to what i need to do.. thanks in advance
08-29-2010, 11:58 AM | #2 |
Happy to be here
Re: c notch already in, want to move trailing arm crossmember back
What type of notch did you use? Most bolt in C-notches have enough wiggle room that you might be able to go back almost an inch. If not, you might be starting over.
08-29-2010, 12:08 PM | #3 |
What year truck?
08-29-2010, 12:13 PM | #4 |
Happy to be here
From a previous post-
08-29-2010, 12:17 PM | #5 |
its a 71 SWB
08-29-2010, 12:19 PM | #6 |
and its a CPP notch
08-29-2010, 12:20 PM | #7 |
and im not sure if it makes any difference, but i have installed a CPP trailing arm crossmember as well
08-29-2010, 12:26 PM | #8 |
With the bolt-in style c-notches for the 6x-72 'curved' frames, there is some wiggle room (per Ken's description ).
There's 2 ways to alter the C/L of the axle in the wheel-well opening: 1) move the rear back; 2) move the body forward. You can shift the bed as far forward as possible for some of the amount needed. If I recall, my 68 had the axle tubes toward the front of the c-notch @ full drop (no springs/bags). So moving the rear back .500 ~ 1.00" should possibly be do-able (not all trucks are the same). I don't think you'll get more than an inch w/the bolt-in style c-notches. But, add the bed shift forward w/a .500-.750" rear end repositioning & you might hit the sweet spot you're seeking. What truck arm c.member are you using? What drop components?
08-29-2010, 05:21 PM | #9 |
My trailing arm cross member is CPP, still have the original trailing arms.. Are the aftermarket trailing arms an exact replica as far as measurments go, or could i be lucky enough for them to be an inch longer? i have not bought any other drop components yet..
08-30-2010, 12:17 AM | #10 | |
ECE's truck arm mounts are bolted to the x.member so they can be unbolted & spaced (easy & cheap). Most aftermarket truck arms are stock length. Porterbuilt is the guy you want to go with to get what you need. Give him a call or send him a PM.
