![]() Join Date: Jul 2010
lt1 engine mount help
Installing a '97 G-body LT1 into my '71 cheyenne super..Will the big block engine mounts work? Is there a mount I can get from lmc or any other after market source?
Too Dumb To Know Better
Re: lt1 engine mount help
you can use the regular small block mounts or the 6 cylinder mount to move it back some
Thanks for the info, got the truck without the 402 and mounts only had the perches on the crossmember. Just ordered perches and mounts from classic perf. products....
Local Detroit diesel nut!
![]() Join Date: Apr 2008
I just used the big block frame stands with small block engine mounts on the engine on my '71 GMC with a '95 LT1 and it worked fine!!! Just had to use a big thick washer on the bolt holding the engine mount in!
Mike
Nothing cool anymore, I am old and boring.... Last edited by schwoch1; 09-05-2010 at 01:35 PM. |
Thought about that...just spent the money anyway,the perches from Classic performance look pretty good though..thanks for the info!
