Old 02-23-2003, 11:06 PM   #1
70jimmy4x4
saggin' rear end !
Well it got you to LOOK !!
On my '70 Jimmy, the previous owner put 3/4 ton leafs in the back and lifted it 3-4 inches. The front is lifted 4" . The right (pass) rear is settng 3/4" - 1 1/4" lower than the other rear side. I took the measurements at the top of the outside wheel well.
Obviously the difference is less noticable at the frame.....
What is the best (easiest) way to level the ride !
Again, the heights are different at the frame AND the wheel well.
Thanks !!
'70 jimmy 4x4
'98 chevy zr2 (the misses' transpo)
'65 stang
'81 shovelhead
'99 Dodge Ram 1500
70jimmy4x4 is offline   Reply With Quote
Old 02-26-2003, 04:21 PM   #2
Mike C
Mike C's Avatar
Have you inspected all of your body mount bushings? Sounds almost like you have two problems. One thing I found with my Camaro when it sat funny was that the FRONT suspension not being right played a big role in the rear.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
