Old 08-29-2010, 09:43 PM   #1
72stepside4WD
What are these #'s on my frame?
What is the meaning of the numbers stamped into the side of the frame rail near the driver-side & passenger-side door? Driver -side # is 3999925 271 5 9 34, see picture. Passenger-side # is one digit different- 3999925 271 5 10 34. The numbers are stamped upside-down.
Also at the very front of the frame rail near the bumper, on the outside, the # 271 is stamped on both sides. Does this mean the frame is a 1971 2wd frame? Thanks for your help.
72stepside4WD is offline   Reply With Quote
Old 08-29-2010, 10:23 PM   #2
71swb4x4
71swb4x4's Avatar
Re: What are these #'s on my frame?
Do any of those numbers match the last six of your VIN?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-29-2010, 10:35 PM   #3
Sammy
Partial vin numbers are common on the frame, also date and year on 71 & 72's.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-30-2010, 12:06 AM   #4
72stepside4WD
So would you say it is safe to say the frame is from a 71 or 72? The numbers on the frame do not match any in the VIN #. Is it possible to determine the year and type (2wd or 4wd) of frame I have using those #'s off the frame?
Old 08-30-2010, 07:44 AM   #5
mrein3
mrein3's Avatar
There is a partial VIN number stamped on the top of the lhs frame rail, about a foot behind the steering box. I don't recall what part of the VIN is there but you'll get somewhat of an idea of what you got.
BTW, 40 year old frames don't look like that up here in Minnesota. Pictures like that amaze me.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-30-2010, 11:28 AM   #6
yote1234
yote1234's Avatar
i belive this is 2-71 feb/1971
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 08-30-2010, 01:04 PM   #7
sameyrasmea72
sameyrasmea72's Avatar
The long # is the part # for the frame or each frame rail. As for the vin # it is stamped in 2 places on the top side of the frame (one under the cab and one by the steering box). The very 1st digit tells what year the frame is (the one in the pic is a 1972), then a Letter which is the plant it was made at, and the the last 6 digits are the part that matches the vin.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 09-13-2010, 12:58 PM   #8
72stepside4WD
Thanks for your help & I did find the number stamped on top of the frame rail near the steering box. It reads 32Z514012, see attached pic. Does this mean it is a 1973 frame? Is it possible that the first 3= 1ton, and the 2=1972, and the Z = Fremont?? Or is it for sure a 1973 frame? I know the truck was pieced together with the cab and engine from a 72, but I assumed the frame was from a 67-72 4x4, not a 73. I would like to know the year frame so when I order replacement parts for the undercarriage, I order the right parts.
Also attached is a pic of the truck, which I have now owned 4 years to the day!
Old 09-13-2010, 03:24 PM   #9
sameyrasmea72
I would bet money that your frame is not a 73. I have heard they are very difficult to convert for a 1967-1972 body. But I guess it could have been. This is the first time I have ever seen 2 #’s in front of the single letter, and I have like 30 parts trucks around here.
72 Cheyenne Super
Old 09-13-2010, 04:21 PM   #10
72stepside4WD
Thanks for the follow up sameyrasmea72. Do you think the fact that it is a 4x4 has anything to do with the 2 #'s in front in front of the single letter? That is why I was hoping that the 3 =1 ton. Do you have any 4x4 frame parts you could reference?? Thanks again.
