Old 08-30-2010, 12:17 AM   #1
leftcoast66
leftcoast66's Avatar
Doing a full frame
So I'm thinking I'm going to do a full frame for my c10. Currently its on bags and I did the four link. Is there any suggestions on doing a full frame. I've read Chassis Engineering and am planning on following the ideas there, as well as the 4 link calculator. Any other suggestions on doing the frame and the math involved? I'm having trouble with where to start? Obviously I'm not planing on buying material for the next 6 months or so, I want to do plenty of research first.
leftcoast66 is offline   Reply With Quote
Old 08-30-2010, 08:29 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Doing a full frame
Do you have room to set up a frame table. That would be my starting point. It will make thing much easier to work on and keep your frame square as you go.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-30-2010, 10:48 AM   #3
colin_havens
colin_havens's Avatar
Only advice I can give you is measure, measure, measure. You can build it on the garage floor if it is level, but a frame table will make it much easier (as well as you arent doing all your work bent over in the floor) Good luck with your project, and be sure to post up some pics! I love this type of fabrication work, its what got me into building airbagged trucks!
colin_havens is offline   Reply With Quote
Old 08-30-2010, 11:37 AM   #4
FnLow69
FnLow69's Avatar
Ya i would build a frame table if you can, or even a wood one would work. I'll i can say is take as many measurements off your old frame as possible and make a drawing of what you want the new frame to look like so you have something to look at, thats where i would start, then get the steel and cut and weld your frame to life!!
Justin
FnLow69 is offline   Reply With Quote
Old 08-30-2010, 03:42 PM   #5
leftcoast66
Thanks guys for mentioning a frame table. I am planning on building one out of wood, something simple but much more level than the floor. Any suggestions for doing the rollcenter and all of the calculations beforehand? I'm assuming start with wheelbase, and what types of link setup and all of that, but should I just start there and let the work begin or is there a more mythodical approach?
Old 04-16-2011, 09:02 PM   #6
ctpchevy
ctpchevy's Avatar
hey hit me up on private msg if you got any questions on this i have built allot of frames ill give you my number if you have some questions as far as the frame table make it out of steel wood will move on you and the steel you can tack peices too it this is my table its still not even big enough but it works for back halfs and check out a shop called BBT fabrication i think thats what its called they did a frame for a 80s burban its pretty sick the front sus is killer he is on street source .com under the builds but yea like the other guys have said take allot of measurements and plan it out
ctpchevy is offline   Reply With Quote
Old 04-16-2011, 11:10 PM   #7
draggin86
draggin86's Avatar
Is that a new frame or old one?
draggin86 is offline   Reply With Quote
Old 04-16-2011, 11:23 PM   #8
ctpchevy
ctpchevy's Avatar
its all new kinda a pain to make those notches but i think the end result will be worth it
Old 04-16-2011, 11:36 PM   #9
ctpchevy
ctpchevy's Avatar
here is the thread of the build of the truck that the frame is for
http://67-72chevytrucks.com/vboard/s...=1#post4629212
