Old 08-30-2010, 12:17 PM   #1
texas56
texas56's Avatar
Removing Cab Trim
Hey guys can someone tell me how to remove the cab trim that wraps the back of the cab on a 1986 Short bed? It is the trim that is under the rear window. Thanks for the help!
1955 First Series Thriftmaster
Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s,
texas56 is offline   Reply With Quote
Old 08-30-2010, 12:24 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Removing Cab Trim
The corner pieces have a bolt that goes through the cab corner, with a speed nut on the back side. You can access it from inside the cab, reach your hand up above where your factory speaker is (or should be) and you'll feel it. The band across the back is held on with pressure clips, with a corner piece removed you can slide it off of the clips.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 08-30-2010, 12:25 PM   #3
baclay9
You have to get the corner peices off first. To get them off you have to reach up inside the back corner off the cab from the inside. Behind the speaker grilles. There is a nut back there that holds them on. Once you get a side off the back pice just slides off from the side.
baclay9 is offline   Reply With Quote
Old 08-30-2010, 12:26 PM   #4
baclay9
You are quick on the keyboard!!!
Old 08-30-2010, 12:29 PM   #5
RandyP
RandyP's Avatar
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=46
Has a picture if it helps you any with those clips. If you want to pop it off instead of sliding it, you press down on the top of the molding and get it to snap off the bottom of the clip, then raise it up and you're free and clear. Some of the retainer clips will probably sacrifice their lives in the process though.
Old 08-30-2010, 12:29 PM   #6
texas56
texas56's Avatar
Thanks everyone!
Old 08-30-2010, 06:04 PM   #7
nbpro
Something a friend of mine did when putting that back on, he put a little silicone just around the edges, and I've seen this on several trucks, to help keep it from rusting and vibrating, causing the paint to have streak marks, if you know what i'm talking about.? I guess what I'm trying to say is theres a little opening with those and water and trash can get in those and make the back of your cab look awful.
nbpro is offline   Reply With Quote
Old 08-30-2010, 06:11 PM   #8
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
Attachment 627271
I just mounted the cab trim on my truck, not that long ago.. (it never had it from the factory),... your saying it's NOT good to add silicone?... that it causes the paint to streak and rust?
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 08-30-2010, 06:16 PM   #9
nbpro
No, I'm saying add it to keep trash from getting behind that piece and causing streaks in the back of your cab. And I'm talking over a period of time. I wish GM would've come up with some kind of rubber molding, kinda like they do on the towing mirrors, the piece of plastic under the crome. It helps keep from rubbing against the doors. Now you understand what I'm saying?
Old 08-30-2010, 06:49 PM   #10
CaliDude76
CaliDude76's Avatar
Ok..lol, now I get it. Hmm, might have to think about trying that,.. actually plan to get the truck painted anyway.. sometime in the future.. might do it then.
thanks for the clarification,... I take in all the advice I can get
CaliDude76
