Old 02-24-2003, 12:10 AM   #1
1969 GMC
1969 GMC's Avatar
Mickey Thompson Radial MTX tires??
I was thinking about putting some Mickey Thompson Radial MTX's on my truck as soon as the current tires wear out. Anyone have good/bad luck with these tires, or hear anything about them? I plan to use them for mostly street, but some mild offroading will be in the plans for them too.
Also, what is the biggest tire size I can run stock (w/o lift)? Thanks.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 02-24-2003, 04:15 PM   #2
Mike C
Mike C's Avatar
I am a DIE-HARD BFG guy. Michelins for street tires, BFG for offroad. (BFG is owned by Michelin) I'd get you some new BFG all terrains for mostly street driving, mud terrains if you are going to be off road a lot.
33 12.5 should fit fine with no lift on a 10" wheel. I ran 33 14.5 on an 8" wheel with only slight rubbing on the leaf spring during sharp turns.
For your 2500, you will most likely need 16 or 16.5 rims, especially if you want to do disc brakes and have'nt. If that is the case, I prefer 16's over 16.5's and maybe even 17's except tires are pricey. I would do 305 75 16 which is ~ 33 12.5 16.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
