What is this?
Can anybody tell me what this is and what it should be hooked up to?
Re: What is this?
Its a dumafloche that operates the whachumajigger. Everyone knows that.
Junior Member
Re: What is this?
Is it on a 6 cylinder engine? My 6 cylinder engine has one on the manifold and I think it was part of the carb linkage when the engine was in the '70 Chevelle. Then engine is now in my '67 swb stepper and has truck linkage.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Re: What is this?
Yeah it's a 6. If I knew where the casting numbers were I'd tell you exactly what 6 it is. I know it has a Monojet
![]() Last edited by lillwr; 08-30-2010 at 06:43 PM. |
Junior Member
Re: What is this?
If it is a 250 it should be on a small flat surface behind the distributor on a the block. Here is an example of the number:V09030CCC. This is the number on the engine in my son's car. I think it is decoded as a 230 L6 from a Carmaro with a 3 or 4 speed.
Junior Member
Re: What is this?
The '70 L6 250 in my '67 has a monojet.
Re: What is this?
Well I'll check it out in the morning. I may need to rebuild the carb or try to figure out how to adjust the float cuz whenever I come to a stop it dies unless I tap the gas
