Old 08-31-2010, 12:23 AM   #1
eclipse85k10
eclipse85k10's Avatar
4x4 Header Pics
I'd be curious to see what headers other out there are running on their 73-87 4x4s. I've been through two sets of hedman hedders on my 85 K10. I've had a hard time keeping the plug wires off the primaries. A few years ago I bought wire holders and yet still I got two wires touching, plus these things make it a pain to change header gaskets. I'm not a fan at all of this style of headers I'm running now, they make it difficult to run plug wires and to remove plugs.
Sorry I dont have pics right now, its 9:30 west coast and I just got done changing a header gasket with frustration so I needed to vent. I'll get a pic of my setup tomorrow in the light.
eclipse85k10 is offline   Reply With Quote
Old 08-31-2010, 12:37 AM   #2
eclipse85k10
Re: 4x4 Header Pics
here is a pic of the style of hedmans I have
Old 08-31-2010, 01:07 AM   #3
Captainfab
60-66 Nut
Re: 4x4 Header Pics
The Hedman #69230's have been a popular header with the guys over on coloradok5.com They don't hang down as low and they clear the passenger side shackle bolt. They are also available in the ceramic coated under #69830.
http://www.summitracing.com/parts/HED-69230/
Old 08-31-2010, 07:41 AM   #4
silvereagle07
silvereagle07's Avatar
Re: 4x4 Header Pics
Will these headers also fit a 84 2wd with vortec heads? I need some for my new engine.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 08-31-2010, 12:35 PM   #5
benoit454
Chris
benoit454's Avatar
Re: 4x4 Header Pics
I had a set of dynomax black jacks and I could get to every plug with a socket and no wires touched or got burnt up. As for the bottom end I'd get the sumit header buddy reducers that are just like ball end like using ball and socket headers so you don't use a gasket at all on the collector, but as for up top in order to avoid replacing gaskets use some copper or aluminum reuseable ones. Some locking header bolts to avoid em backing off, and try to get a thick block side flange if you can to avoid warpage.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 08-31-2010, 04:00 PM   #6
82swampthing
82swampthing's Avatar
Re: 4x4 Header Pics
hooker headers they fit real nice even with the z bar for the clutch in the way.As far as wires go I cut my own so would fit right and not have a mile of slack like most aftermarket sets do.
R.I.P gm 1908-1986
1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f
82swampthing is offline   Reply With Quote
Old 08-31-2010, 05:20 PM   #7
68 TT
Still plays with trucks
68 TT's Avatar
Re: 4x4 Header Pics
I have these and they fit pretty well.
http://www.summitracing.com/parts/SUM-G9006/
The smaller tubes make for better low end power and they have thicker flanges than the Hedman 96230's so they shouldn't warp as easy.
Easy plug access except #6 where you have to use a wrench on the spark plug socket. Not even close to as difficult to work with vs. the Hookers I used to have.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-31-2010, 05:24 PM   #8
Tex_50613
Redneck Customs Bumpers, IA
Tex_50613's Avatar
Re: 4x4 Header Pics
hooker longtube truck headers on a 83 chevy 3/4 ton 4x4 manual trans
accell header plugs, accell universial fit plug wire set cut to leingth and routed to clear everything
Tex_50613 is offline   Reply With Quote
Old 08-31-2010, 09:10 PM   #9
benoit454
Chris
benoit454's Avatar
Re: 4x4 Header Pics
I got them same headers on dad's 84 c10 and was not happy with them, the flange was just as thick as regular old cheap flowtech and they actually had flowtech part numbers on them, well the no. 1 tube on the DS hit right on the spark plug and I had to dimple the tube to clear the plug. Then they hang down below the truck at an angle. Now it's not bad but it causes the pipe to have to have a bend in it you can't run a straight pipe off it because it'd eventually hit the ground. Them being tilted down in back and hitting the no.3 plug made me really mad. Now on ebay you can get what looks like the same headers in stainless for $158 and IMo I'd jump on them for sure.
Chris
GIT R DONE!!!!!!
Old 08-31-2010, 10:11 PM   #10
Chlsnk
Chlsnk's Avatar
Re: 4x4 Header Pics
Could you tell me how far below the frame rails they hang and mabey a picture ? I lowered my truck and am having header scrape problems.
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 09-01-2010, 07:24 AM   #11
BigBlocksRule
Re: 4x4 Header Pics
Vortec heads have no special header considerations, if they'll fit the truck, they'll bolt up to the Vortecs.
BigBlocksRule is offline   Reply With Quote
Old 09-01-2010, 07:29 AM   #12
silvereagle07
Re: 4x4 Header Pics
Cool! Thanks alot. Now I need to find some that do not hang below the frame. My truck is really low.
Jeramy
'85 Chevy 4X4 SOLD
Old 09-01-2010, 11:25 AM   #13
68 TT
68 TT's Avatar
Re: 4x4 Header Pics
They must have changed since I got mine almost ten years ago. I had none of the problems you describe and have put the same old set on three different trucks now. They have held up well.
I might take a look at the ebay ones for my 67.
Old 09-01-2010, 09:47 PM   #14
eclipse85k10
Re: 4x4 Header Pics
took some pics of my headers and plug wire setup and a picture how low my collecters are below the frame
Old 09-01-2010, 10:09 PM   #15
Skratch
Skratch's Avatar
Re: 4x4 Header Pics
I don't have any pics of mine, but I ran with the Edelbrock TES system.
No problems with any of the gaskets or dounts and it's just as easy to get to the plugs and wires now as it was when it had the stock manifolds.
The only issue I had with mine was that despite being made for the 4wd, the y-pipe didn't clear my front driveshaft . . . course the suspension lift, clocked and raised transfer case probably didn't help either.
If it ain't broke, then I haven't fixed it yet!
'86 Fiero SE 2M6 (undergoing a Northstar swap)
'87 1/2t 4wd Suburban (4" lift with built 1t axles and beadlocks)
'90 3/4t 2wd Suburban (Tow Rig)
'94 3/4t 4wd G20 Van (Toasted tranny and rusted)
'96 Deville
Skratch is offline   Reply With Quote
Old 09-01-2010, 11:40 PM   #16
benoit454
Chris
benoit454's Avatar
Re: 4x4 Header Pics
these are the summit brand headers from above we bought for the 84c10 and they had the flowtech number on the box, not sure if you can see the issue on the 2nd plug(no. 3 cyl.) on the DS or not..
The dynomax headers we had on a 76 c10 with stick shift, and then put em on the auto 86 4x4.
Chris
GIT R DONE!!!!!!
