08-31-2010, 12:18 PM | #1 |
interior door handle remove
Any good techniques for removing these handles? They are stuck and I don't want to bugger up the trim. I've got to fix the door latch (yep it's on the driver's side).
08-31-2010, 12:24 PM | #2 |
Restoring it $200 at a time...
Re: interior door handle remove
There's a c-clip that anchors the handle to the actuator in the door. Gently push the panel in and look down to the backside of the handle for the visual. The window crank has the same clip, if that works better. You might be able to use a long flat screwdriver to push the clip off. I have notched the shaft on a Phillips screwdriver that allows me to catch the clip and pull it. Sorry no pics.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
08-31-2010, 12:35 PM | #3 |
Redefining LowBudget
bend a paper clip about 1/8" with the hook facing you slide it in behind it oposite the handle..with a little fishing you will hook it then gently push the handle in and pull the clip out...the clip may wanna fly so keep an eye on it...place the clip back on the handle and press it on when your done
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
08-31-2010, 01:30 PM | #4 |
autoparts store has trim removal tools for cheap
08-31-2010, 01:55 PM | #5 |
Junior Member
use a shop rag. not sure how to explain it ill take a pic
frontstreetcycle on Instagram |
08-31-2010, 01:58 PM | #6 |
Here's a shot of the tool. It is engineered to prevent the c clip from shooting off into space, just sliding it back far enough to get handle off.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 |
08-31-2010, 01:58 PM | #7 |
1970 C10 six
The removal tool is the best if you want to buy one. If not the screw driver works just as good.
08-31-2010, 01:59 PM | #8 |
I always use a butter knife.
I'm not as good as I once was, But I'm as good once as I ever was. |
08-31-2010, 03:17 PM | #9 |
Junior Member
just wiggle it back & forth till it catches & pushes the clip off. Usually the clip gets stuck in the rag so you dont lose it. 1000 times better than any tool.
frontstreetcycle on Instagram Last edited by scrapmetalart; 08-31-2010 at 03:18 PM. |
08-31-2010, 03:36 PM | #10 |
78K & 79C Jimmys
i use a small screwdriver,till i seen this rag trick thats cool thanks
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
08-31-2010, 05:10 PM | #11 |
20' Daredevil (Ret)
I used screwdrivers many times, it's usually a struggle and you may end up shopping for a new spring clip. The tool you pictured is cheap and works extremely well, and you don't lose the clip.
08-31-2010, 10:38 PM | #12 |
Thanks all, much good advise.
08-31-2010, 11:18 PM | #13 |
The tool is cheap and readily available just good to have around...now if some of the aftermarket handles/clips would stay on/fixed as the originals do...don't throw away the old clips they sometimes work better...FYI
08-31-2010, 11:20 PM | #14 |
Man of Mini-Talents
Cool tip - I'll give that one a shot.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
09-29-2010, 06:26 PM | #15 |
thanks, guys!
'72 Chevy Cheyenne Super, '56 Chevy Bel Air,'56 Chevy Nomad, '61 Chevy Impala, '64 Cadillac Fleetwood, 1966 Thunderbird Convertible |
09-29-2010, 08:05 PM | #16 |
09-29-2010, 08:30 PM | #17 |
X2
09-29-2010, 09:11 PM | #18 |
great idea, i just bought a truck and the original wood grain door panel is a messed up from someone before me trying to remove the handle
09-30-2010, 02:04 AM | #19 |
I am impressed with the rag trick. I am going to try it tomorrow.
1971 Chevy C-20 Flatbed SBC350/Turbo 350 "Torque Is Controlled Power" |
10-03-2010, 01:11 AM | #20 |
I tried the rag trick today. So simple and the color of the rag doesn't even matter. LOL
03-06-2015, 04:45 PM | #21 |
Rag trick worked like a charm. Thanks!
Now if it were just as easy to fix those broken brittle plastic pieces behind them.
1979 C-10 LWB |
03-06-2015, 05:02 PM | #22 |
i just use needle nose pliers and open it up so the tips push on the clip till it pop off into my hand
01-08-2016, 03:40 PM | #23 |
Raising this thread from the dead....I have the interior door handle clip removed. Is there anything else I need to do to remove it. I ask this because the C clip is out and my handle will not come off. I wanted to ask before I used elbow grease
The stupidty of your actions is directly proportionate to the number of people watching you... |
01-08-2016, 03:45 PM | #24 | |
Posted via Mobile Device |
01-08-2016, 03:47 PM | #25 | |
