Old 02-24-2003, 02:07 AM   #1
match71gmc4x4
Question installing a 71 GMC parking lens
To all the GMC owners,
I am trying to change both my parking lens in my 71 GMC. I am not sure how to change them out. Do I need a special tool to change these out? Any help would be appreciated.
match71gmc4x4 is offline   Reply With Quote
Old 02-24-2003, 02:47 AM   #2
barn9
Half a bubble off!
barn9's Avatar
Screwdriver always works for me.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 02-24-2003, 07:19 AM   #3
GMCPaul
Best method is take a cheap small C-clamp and grind the pad off the screw end and grind the end to a bevel, then very carefully insert rivet through lens from front and through housing place pad side of clamp on rivet head and tighten slowly, the bevel you have ground on end of threaded screw on clamp will split the blind rivet, if you have a blunt bevel you can continue to tighten until rivet is crushed flat on back BUT BE CAUTIOUS AS TO TIGHT AND YOU CRACK THE NEW LENS. If your bevel on screw was not blunt enough when point bottoms out the lens may still be lightly loose, if so you can blunt tip more after getting all rivets intially split then finish crushing them flat. You got it easy barn9 changing Chevy parklight lenses.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 02-25-2003, 11:31 AM   #4
match71gmc4x4
GMC Paul,
Thanks for the information, I got my parking lens' put on yesterday and going to get them installed on my truck tomorrow. I should be getting my truck back from the paint shop tomorrow. I will try and get some photo's posted when I get my truck.
Old 02-25-2003, 12:23 PM   #5
Project1970
14.1 @ 96MPH
Project1970's Avatar
Am I missing something here? I can't think of a lens on my truck I don't get at with a Phillips screwdriver...
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 02-25-2003, 12:31 PM   #6
barn9
Half a bubble off!
barn9's Avatar
Whoa! I didn't know GMC's were so complicated! Sorry I was such a smart-a**. Rivets? Sounds like a good spot for improvement. Glad I have a Chevy!
Just call me LB.
Old 02-25-2003, 02:51 PM   #7
Slammed67
Progress = 0%
Slammed67's Avatar
I replaced my rivets with small stainless steel screws/nuts. The grill covers them, so they aren't visible anyway.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
