Disc Brake front brake line size
I've got a questions about brake line fitting size for a disc/drum setup. I converted my 67 4x4 to disc front/drum rear axles from a 79, and because I had drum/drum before I modified the plunger shaft to make the 79 master cylinder work with a 72 power booster I had. That master cylinder is now on the frits and I want to replace it.
If I get a 67-72 correct disc drum master cylinder will I have a different brake line size? I'll try to confirm what size I currently have, but does anyone know what size the stock front disc brake lines would be? 3/8? 5/16". Also after struggling to bend my own and keep em tight to the cross frame I am seriously considering the prebent lines; anybody used them before? how do they fit?
time is inversely proportional to money; that's why it takes me so long 1967 K10 1967 Camaro |
Re: Disc Brake front brake line size
Not sure if this is the same for a 4x4 or not but I got my disc brake upgrade kit from Early Classic and they sent me a 3/16" line for the front discs. The stock drum front brake line is 1/4". The 1/4" line for the rear drums stays the same.
1970 Chevy LWB - 305/350 In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's. Last edited by swierker; 08-31-2010 at 03:25 PM. |
sharp as a marble
![]() Join Date: Jan 2007
the front line size is 3/16, and the lines running to the rear are 1/4. I would think that the 79 lines are the same. If you have the old lines, use them as a guide to bend the new lines. There are a bunch of inexpensive benders out there the will help you bend the new lines. Replacement brake lines available from any parts store are seamless thin wall tubing, that will not kink with a gentle bend. IMO you will need a bender to make a 90 degree bend to keep them from kinking. we replace a bunch of lines on late model stuff with out a bender. it will not look exactly like what we removed, but will work. the attention to detail to what you do will be proportionate to the time you put in it
