08-31-2010, 03:39 PM | #1 |
New to me 71 GMC, a few questions
I've been lurking these forums for awhile but just last sunday I bought a 71 GMC for my daily driver and it has a few quirks that I hope the experts here can help me straighten out.
First off some details: 1971 GMC 4x4 LWB 350ci V8, TH350 3-4"? home made body lift 31x10.5" tires First thing to raise some questions was the VIN. It starts with a 'C' but the truck is 4 wheel drive. So I assume a previous owner swapped a cab off a 2 wheel drive. The thing I couldn't figure out though, in the digit where the year usually is it has '-' instead of any number 7, 8, 9, 0, 1 or 2. The second thing that I'm unsure of is the tranny dipstick. The stick is brand new but when I checked the fluid level after driving it 2 hours home (with no problems) there isn't a drop of fluid on it. The stick is about 34.25" long and from eyeballing the tube I think its too short. How long should it be? Third, are the front leaf springs on the 4x4 models originally flat? I was expecting them to have some upward arch but mine have a slight downward arch. I was wondering if they were flat originally and sagged down over time. Fourth, my fuel gauge always reads empty. Is the wire running to the sending unit on the tank the ground or power? I cleaned up the wire/connection on the outside thinking it was the ground. Unplugging this wire from the fuse panel under the dash buried the needle on the fuel gauge so the gauge itself works. What is my next step? I'm thinking either the float doesn't float inside the tank or there's a short in the ground. Where is the ground for the sending unit located? Lastly with the body lift in place the mechanical fan doesn't line up very well with the radiator causing it to run hot idling. I've read a few electric fan swaps (jeep fans, lincoln fans, etc) but has anyone used the 16" electric fan kit from LMC (or a similar all inclusive kit)? I've never done an electric fan upgrade so I was thinking a kit would be the best way to go so there's less chance of me screwing it up. Also, are there any small upgrades I should consider that are done to these style trucks by expierenced people? What I mean are upgrades specific to this style truck that among people familiar with them are pretty much common knowledge (i.e. something about getting a 4-4.5" tall air filter?). Anywho...appreciate any help/experience you guys can share. Last edited by Christiansok; 08-31-2010 at 03:48 PM. |
08-31-2010, 04:22 PM | #2 |
Re: New to me 71 GMC, a few questions
Congrats on your purchase and Welcome! Pics are required, you know .
I'm thinking maybe a 4x4 conversion, what does the registration say?
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
08-31-2010, 04:27 PM | #3 |
Welcome to the board always nice to see another 4 eyed guy on here. Make sure on the Vin decoder that you are looking at the GMC decoder, because I had the same problem but I was looking at the Chevy decoder
Post some pics of the new truck
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!! |
08-31-2010, 04:47 PM | #4 |
I suppose a teaser pic is in order, took this with my phone stopping for gas before I drove it home. Maybe its just me but the front axle does seem shifted backwards off center in the wheel well so maybe a 4x4 conversion is what happened??
08-31-2010, 05:20 PM | #5 |
How did you put that hood on there? Thats a older hood.
~~'71 GMC shortbed. Recently, 2007 Mazda 3 hatchback. |
08-31-2010, 05:43 PM | #6 | |
08-31-2010, 06:07 PM | #7 |
Looks as though the "Chevy" fenders have been modified to fit the hood.
Edit: Actually, something doesn't look right with the fenders.
My goal in life is to be as good a person as my dog already thinks I am - Unknown Last edited by GruntMoanCough; 08-31-2010 at 06:10 PM. |
08-31-2010, 06:24 PM | #8 |
Here's some more pictures of the hood/front clip that may help clear things up
And here is a side shot where the front axle positioning looks kind of off to me (shifted too far back) |
08-31-2010, 07:09 PM | #9 |
IMO I think its an illusion because the fenders dont have the eybrow mouldings on them but the hood does. The hood definitly needs to be moved back, but I dont think they're Chevy Fenders because the grill is sitting flush like it should, I think with the other fenders it wouldnt fit right
08-31-2010, 07:11 PM | #10 |
It seems like you might have the same problem with the rear axle too if you look at your last picture, I dont know just a thought is there any adjustment in the bodies on these trucks that you could basically move the body back an inch or two to fix it
08-31-2010, 09:39 PM | #11 |
Roadtrip!
Decent looking truck. I would check numbers, VIN glovebox door, etc to make sure of what it is. It looks like a 67 cab, 67 box, 68 hood, 69 and newer fenders.
The leafs i wouldn't worry about. They are usually flat or arched the wrong way after this many years.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
08-31-2010, 10:25 PM | #12 | |
Ray |
08-31-2010, 11:30 PM | #13 |
Thanks Ray, I'll pull the sending unit out next and check the float.
I was looking around for some VIN info for GMCs and found this: http://outintheshop.com/vin_decode.html So it turns out the GMC VINs are only 12 digits with a hyphen? According to that website I have, 4x2, V8, 1/2 ton, Fleetside, Jainesville, 1971 My model number (if its the same chevy/gmc) on my glove box door, CS10934 tells me that its a 4x2, inline 6, 1/2 ton, fleetside....so thats even more confusing... On the line right under the Model number I can make out 292...is the line below the model number related to the engine? Would make sense if the model number says it has a straight 6 then below it says 292...but that just confuses me more because the model number/VIN conflict with each other. Last edited by Christiansok; 08-31-2010 at 11:31 PM. |
08-31-2010, 11:54 PM | #14 |
I have a 1969 Gmc 2wd and i say the the earlier model hood looks smoother than the later ones with the squared off face
It would be cooler if u did |
09-01-2010, 12:00 PM | #15 |
Maybe its me but,the rear shocks are mounted(upper) on the outer frame rails which makes me think some has been changed.Usually they are mounted on the inside frame rail
09-01-2010, 12:22 PM | #16 |
Maybe the body was swapped onto a different frame? That could explain the front axle shifted back, the 4x4 conversion and the body lift. Any features to look for to identify the frame as a 71?
09-01-2010, 12:48 PM | #17 |
For those suggesting the front clip, cab and bed are 67-68 what do you look for to tell? The front of the hood has the laid back angle and the cab has the small rear window, do both of these signs point towards 67-68?
09-01-2010, 03:31 PM | #18 |
You definitly have a 67/68 hood, no question, the fenders are 68-72 GMC, 67 parts would have no marker lights in them at the corners so from your pics it looks like your bed is a 67, either that or someone filled in the marker holes, and the small rear window is a 67 only deal, so you definitly have some mismatched parts on there......So it really makes you no difference than the rest of us LOL
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!! Last edited by gregg72340; 09-01-2010 at 03:32 PM. |
09-01-2010, 04:20 PM | #19 |
Thanks for the help Gregg.
So shes a miss matched bag of parts, oh well haha But this does raises some questions because the VIN plate on the cab is for a 71 but the cab is definetely a 67...so someone must have transplanted the VIN plate to the older cab? Is this acceptable? |
09-01-2010, 06:34 PM | #20 | |
Gregg
09-01-2010, 07:29 PM | #21 |
Those are 68 GMC front fenders you are missing the 68 style eyebrowls
