Old 08-31-2010, 05:43 PM   #1
BigRed76
BigRed76's Avatar
Spare Tire Carrier
I searched the forums and didnt find too many pics. I know alot of people don't like the under-bed spare tire carriers, but i like the idea and want to get one. What i need though is some good pictures of how the carrier attaches to the frame and how the tire sits when in the carrier. The only reason i need pictures is to see if my exhaust will be in the way. Any help with this would be awesome
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 08-31-2010, 06:08 PM   #2
Prerunner1982
Prerunner1982's Avatar
Re: Spare Tire Carrier
I believe there may be two different versions... don't quote me though. I don't have pictures, but there is a large "plate" with a lip to catch the under side of the wheel so it doesn't slid around. At the front end of the carrier is a long bolt that bolts to the frame and to the carrier. The other end is also a long piece of threaded rod that has a piece that you thread on and off the rod to secure/lower the tire carrier. I believe the solid side of the tire carrier is on the driver's side frame rail, while the side you raise/lower is on the passenger side. You should see a hole on each rail at an angle from each other (may be a bunch of other empty holes down there as well).
See LMC catalog page for a better idea. This page also confirms that there were two underbed spare tire carriers.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=32
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 08-31-2010, 07:35 PM   #3
tucsonjwt
I have the standard spare tire carrier on my 83 C20. I had to move the threaded bolt forward a couple of inches in order for the spare tire to clear my receiver style under frame trailer hitch. I think this is why most carriers are not present - they interfere with a trailer hitch.
The pictures are not very good, but you can see the modified location of the carrier bolt brings the tire very close to the exhaust, but the exhaust is not touching the tire (tire on one side of the bolt, exhaust on the other side of the bolt, with about 3/8" of air space on either side.
I also had to have the rear bumper notched out to clear the box when it is in the full dump position, which is why it looks odd (pictures are with the box in the full up position.)
As I recall, when I got all of the bits and pieces from LMC the total bill was about $100 and I had the top cross piece still in place - looks like prices have changed. All of the parts I got were "imported."
tucsonjwt is offline   Reply With Quote
Old 08-31-2010, 09:05 PM   #4
BigRed76
BigRed76's Avatar
Thanks for the pics tucsonjwt, judging by your truck i dont believe i will have any issues with the exhaust. What size of tire do you currently have in the carrier?
Zach
Old 08-31-2010, 09:09 PM   #5
Hubscrub
Cruzin
Hubscrub's Avatar
just a thought, some people use the later model cable style that you can crank up and down
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 08-31-2010, 09:13 PM   #6
BigRed76
BigRed76's Avatar
I honestly dont know much about them
Zach
Old 08-31-2010, 09:14 PM   #7
tucsonjwt
The spare is 235/85R16.
Old 08-31-2010, 09:54 PM   #8
BigRed76
BigRed76's Avatar
yeah so max i would probably be able to fit a 31x10.50R15 in there, which kinda sucks cuz i will be running 35's in the near future
Zach
Old 08-31-2010, 10:03 PM   #9
78 Chevyrado
I had a 31x10.50R15 under the bed on my 77... Thats the max size I can see fitting under there with all stock parts. And the tire was wide enough, you won't be getting the tire hung back up there on your own.... need 2 people and a floor-jack to place it under there.
78 Chevyrado is offline   Reply With Quote
Old 08-31-2010, 10:07 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Thats exactly what I would do if I were starting with nothing. The later model are easy crank down vs the old style that require a hack saw, pry bar, curse words, and WD-40 to work.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-31-2010, 10:09 PM   #11
BigRed76
BigRed76's Avatar
is the cable style used on the 88-98's?
Zach
Old 08-31-2010, 10:25 PM   #12
3r!c84
Badass
3r!c84's Avatar
could i put a under bed tire holder on a lowerd truck?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-31-2010, 10:34 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Yes. From 88 til present they used some sort of cable style
Originally Posted by 3r!c84 View Post
could i put a under bed tire holder on a lowered truck?
Slightly lowered maybe. Much more and it's gonna drag.
Articles-
"Refining Sierra"
Old 08-31-2010, 10:36 PM   #14
3r!c84
Badass
3r!c84's Avatar
4/5
-00 Saturn 5spd
1/4:13:90
Old 08-31-2010, 11:34 PM   #15
C-10 simplex
i've been thinking about this myself for a while, but probably won't be able to get to it for a while. But in the meantime:
i can't fit a "regular" (235/75 15) tire underneath there either due to trailer hitch and dual exhaust intereference issues.
However, i feel that since a spare is just temporary-----you only need it for as long as it takes to repair or replace the flat, then a smaller tire could be and should be used. Even a temporary "donut" type.
i think some astro vans, which have the same 5X5 bolt pattern, had a temporary type spare.
Then with 2 metal "straps"/crossmembers bolted to either the frame or trailer hitch, this would form a cradle for the tire to rest in. Then maybe use a chain to secure it in there.
The temp spare would(hopefully) be light enough so that getting it in and out would be no problem.
C-10 simplex is offline   Reply With Quote
Old 09-01-2010, 11:08 AM   #16
tucsonjwt
If you look at my pics, you can move the threaded bolt forward about two inches to clear a trailer hitch and still miss the exhaust. If you have mod exhaust or monster trailer hitch, or fat tires, it might not work. My exhaust goes out the side after the rear axle.
Old 09-01-2010, 12:14 PM   #17
Adams74Chevy
Adams74Chevy's Avatar
Originally Posted by C-10 simplex View Post
...However, i feel that since a spare is just temporary-----you only need it for as long as it takes to repair or replace the flat, then a smaller tire could be and should be used. Even a temporary "donut" type.
i think some astro vans, which have the same 5X5 bolt pattern, had a temporary type spare...
I suppose it would be ok if you didn't have any load as well, that is something to definately take into account.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 09-01-2010, 12:53 PM   #18
C-10 simplex
1) Will check.
2) P.S. The astro temp spare might fit behind the seat even.
