Old 08-31-2010, 06:22 PM   #1
djmachinist
djmachinist's Avatar
Does your seat back pivot forward?
My seat back on my 69 GMC does not pivot forward. My Buddies 65 Chev. stepside does. I have removed the gas tank and put a CPP aluminum tank under the bed. I would like to put a Stereo/Speakers behind the seat now that I have more room back there, however I would like the seat to pivot forward to gain access behind the seat. I don't want to un-bolt the seat everytime I need to get back there. Were all 67-72 trucks provided with a non-tilt seat back?
Any ideas? Oh.....I'm talking about Bench seats.
Dale
1969 GMC SWB FLEETSIDE
ZZ 383 CRATE MOTOR,700R4,& 3.73 POSI & VINTAGE AIR
DALE JONES
MY BUILD THREAD: "69 GMC SHORT FLEET"
http://67-72chevytrucks.com/vboard/s...d.php?t=388447
djmachinist is offline   Reply With Quote
Old 08-31-2010, 06:38 PM   #2
GRX
GRX's Avatar
Re: Does your seat back pivot forward?
Yes, the seat in my '69 stepper pivots forward. Not sure if it's stock though.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 08-31-2010, 06:38 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My '69 doesn't. I don't remember for sure, but it seems that the four '65's I had, did.
Member Nr. 2770
Old 08-31-2010, 06:39 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Yeah, the older trucks had that option. Safety concerns mandated that they be locked in the upright position, not sure what year, but I believe either 67 or 68.
68gmsee is offline   Reply With Quote
Old 08-31-2010, 06:51 PM   #5
burb71
Active Member
I have a set of 1967 buddy buckets and the driver side seat back pivots forward.
burb71 is offline   Reply With Quote
Old 08-31-2010, 06:54 PM   #6
John Fabris
TOTY 2006
John Fabris's Avatar
Look at the pivot arm of your seat, (both sides) there is a stop on the arm and you have to remove the nut, and voila, you seat should now pivot. Can load pictures tonight for clarification.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-31-2010, 07:19 PM   #7
djmachinist
John,
I was just outside in tne garage and "What You said"!!! I found the two countersunk phillips head bolt locking the pivot. Removed the two bolts,
and sure enough, the seat pivots forward! It seems to have some kind of stop where the back won't tilt back too far.
Thanks,
Dale
DALE JONES
Old 08-31-2010, 07:19 PM   #8
GruntMoanCough
GruntMoanCough's Avatar
My '68 does ...... My '72 doesn't
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 08-31-2010, 08:26 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Lots of guys removed that second bolt back in the early years. If you're ever in a head on collision you'll find out why the government didn't think it was a good idea.
Not sure why everyone wants it to pivot. I guess it helps when replacing the sending unit every 10 or 15 years or if you've removed the tank and use the back of the seat for storage.
