Manual to power steering conversion
Everybody always asks about the brake swap from a 73-87 to our trucks, but can you use a power steering box when you do the conversion as well, I know the fittings can be an issue but are there any other snags?
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!! |
Re: Manual to power steering conversion
I put the later box on my '72 swb about 25 years ago. The details are a bit foggy now, but the box bolted right on with no mods needed. The box that I used required a different style of hose end than the original did, but, the box you choose may not. Physically, the hoses would bolt up, but they would not seal. I made some adapters to make it work. Most parts houses can custom make the hoses now, so you could just get them made with the original ends for your pump, and the ends that your new box requires, if they are different than the original.
#3 | |
Old Skool Club
![]() Join Date: Jun 2001
I think the only issues are when you have an early '67, compared to the later ones and on through '72. There's something about the frame, where the box mounts that is an issue. You didn't say what year you have, though.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
I have a 68 so it SHOULD have the bump to fit a power steering box.....Hopefully anyway LOL
Old Skool Club
I work with a guy who has the '67 LWB Fleetside that he bought new, as the '68's were about to come out. He added PS to it, last year, after he found that his age was starting to catch up to his abilities. He found a complete unit from a '72, in a wrecking yard. Got the pump, pulleys and steering box and put it on his truck. Here's his truck.....
frame is the biggest issue, if it's an issue at all. 68 4WD's still had the flat frame and require a bracket to mount the box. Be sure to pull all of the parts from the donor including bracket (if it mounts to your block, not the heads) pump, pulley's... I found it difficult to get all of the pulley's to match up.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Just put ps on my 68 and it was no problem. I would check with teeitup as he gets really good parts and passes on the deals. I would also suggest to get the 71-72 bracket set as the correct 68 bracket is tough if the motor is not pulled (it took 2 hours to install the support bracket) there were only 4 bolts , but the 68 mounts under the motor pad.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
