Back in the sticks
Body mount spacers
What are you all using for body mount spacers? I looked at some 1/2 inch washers, but they aren't nearly big enough around. What have some of you used in order to get your lines straight. Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Back in the sticks
Re: Body mount spacers
Nevermind, I saw TRZ's post in AK's post. McMaster-Carr has it all...
Back in the sticks
Oooo, maybe not. They want $15 each!
Yeah, they can get spendy. I was able to minimize the cost by picking and choosing the right size and stacking them. A 1/4" shim is $15.63, while 1/8" is $4.73 so you can get your 1/4" for $9.46.
I had some gaps between some of the body mounts and the tub so I used a feeler gauge set to get an idea of what I needed. I spent about $50 and have probably 5 extra shims. I bought an assortment of 0.125, 0.100, 0.60, and 0.50. If I did it again I'd go with 0.100, 0.50, and 0.25. That would have been more than sufficient size variability to make things work. If I remember right I had 3 mounts that needed some spacing and all the gaps were different. Had they been closer I would have just gone to the steel pile and grabbed some 3" flat stock of desired thickness and made my own shims. No where near as accurate but if it was say 1 body mount that needed attention it would be very doable. Good luck! |
![]() Join Date: Oct 2009
if you know a lineman, the washers for power poles work great!
#6 | |
Back in the sticks
Thanks, Ya, I think I'm going to need some different sizes. It looks like at least a half to 1 inch on one and around a 1/4 on the other one. At least I hope that'll get me in the ball park.
Back in the sticks
hehe, ya I was looking at washers too, but they are almost as expensive as the spacers from McMaster.
x2 I'm a lineman by trade, and I've thrown enough of those washers away to cover a house. k5blazin is right, if you can locate a power co. or phone co contractor they will probably give you all you would need. (or for a 12 pack)
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
Back in the sticks
hehe, thanks for the heads up! I'll be looking you up for a job when I retire anyway.!!
I bought a couple of 3 1/2" pieces of flat stock from lowes in 1/8" and3/16" thickness cut them square and drilled a 1/2" hole in them. a little bit of work but had all i needed. i used a chop saw and driil press to drill several shims at a time.
Back in the sticks
Good idea! Should have thought of that myself.
#12 | |
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
