Old 09-01-2010, 11:55 AM   #1
Overdrive
Sawzall User
Overdrive's Avatar
Location: The snow infested Prairies of Canada (aka: Winnipeg, Manitoba)
Question '73-87 Column in a '67?
I have an '84 6.2 diesel C10 that was my daily driver till a deer smashed it, so I am trying to see what I can use in my '67 GMC. I am wondering about the steering column, and how these fit in the '67-72 trucks. I know it has the key on it (not a big deal), however it's a floor shift tilt column, and I would like to use it if it's not too much of a pain. I'm also using the 4-speed transmission and hydroboost brakes out of the donor truck. The engine needs work, so I'm likely not swapping that in right now.
Anybody done this column swap? How do they compare in length and mounting plates, etc? Wiring is not an issue, I can figure that out.
'67 GMC 910
Overdrive is offline   Reply With Quote
Old 09-01-2010, 12:16 PM   #2
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: '73-87 Column in a '67?
From what I've read the column is almost a straight swap. Only diffrence is how it's mounted. You will have to do a little fab work, but not much. I'm gonna run the same column in my 64.
Do a search on here, several people have done the swap.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 09-01-2010, 12:57 PM   #3
Overdrive
Sawzall User
Overdrive's Avatar
I've searched for quite a while and seen lots of mention of people doing it, just nothing with photos or details on what's different or what needs to be done.
'67 GMC 910
Old 09-02-2010, 07:32 AM   #4
Zeke
Active Member
Can't find it but there was a post with a picture, said column bolted in but had to cut the instrument bezel because it's bigger diameter. I have an 81 tilt that I am going to try and fit up but haven't got to that point yet.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 09-03-2010, 02:13 PM   #5
Overdrive
Sawzall User
Overdrive's Avatar
I'll have to measure my columns. If it is a bigger diameter, I might consider a stock tilt, or if I can't find one, a van tilt or an aftermarket column...
'67 GMC 910
