Old 09-01-2010, 12:04 PM   #1
PLANETGETLOW
Post Your 4-Link or 3-Link Setups!!
I need some ideas folks.....
PLANETGETLOW is offline   Reply With Quote
Old 09-01-2010, 08:38 PM   #2
PLANETGETLOW
Re: Post Your 4-Link or 3-Link Setups!!
Anybody?
Old 09-01-2010, 10:13 PM   #3
mac72
Man I was bent on fabbing my own setup & by the time I added it all up I was close enough to SD's price so I just ordered their kit,it saved me alot of time & effort
mac72 is offline   Reply With Quote
Old 09-02-2010, 12:43 AM   #4
Ronm909
67GMC Slammed
Ronm909's Avatar
here is mine.. I'm not gonna lie, I have stolen ideas from vaious other members
my dropmembered 67 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383215
Ronm909 is offline   Reply With Quote
Old 09-02-2010, 12:03 PM   #5
67cheby
67cheby
67cheby's Avatar
mine , a little Porterbuilt, a little Suicide doors, a little Mayhew race cars , a little KP components all rolled into one
67cheby is offline   Reply With Quote
Old 09-03-2010, 01:26 PM   #6
68laydout
Junior Member
68laydout's Avatar
68laydout is offline   Reply With Quote
Old 09-05-2010, 03:04 PM   #7
PLANETGETLOW
Thanks guys.
My question for those with the 3-link and trailing arms: Did you install trailing arms just for the bags (mounts)? If not why would you run both?
Old 09-08-2010, 06:54 PM   #8
PLANETGETLOW
Originally Posted by PLANETGETLOW View Post
Thanks guys.
Bump
Old 09-08-2010, 07:20 PM   #9
mac72
planet, I'm not sure I understand your question,but I'll take a shot at it.
The susp. systems that are posted all require lower bars to keep the axle from twisting because all the mounts at the axle 3 or 4 link/ upper or lower, pivot.This keeps the pinion angle pretty consistent thru the suspension cycle,unlike the factory trailing arms wich are fixed to the axle.The only real diff. between 4 & 3 links is the upper wishbone allows you to eliminate the track bar & still keep the axle centered side to side.The bags are mounted on the lower arms mainly for convenience.Hope this helps , Mac
Old 09-09-2010, 12:29 AM   #10
FnLow69
FnLow69's Avatar
Thanks guys.
Most people mount the bags on the lower bars for the canti-lever effect, meaning more lift out of the bag.
FnLow69 is offline   Reply With Quote
Old 09-11-2010, 02:52 PM   #11
PLANETGETLOW
Thanks fellas.
Old 09-15-2010, 12:12 PM   #12
PLANETGETLOW
Is there any reason to keep the leaf-spring setup if running bags?
Old 09-15-2010, 07:36 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Sure there is. If your not planning on going really low and you don't want to cut the bed, a "Air over Leaf" system will do the job just fine.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-16-2010, 10:25 AM   #14
PLANETGETLOW
Gotcha. We plan on layin frame or close to it and the bed is already cut so these would have to go.
