![]() Join Date: Apr 2007
hood interchangeability 67 - 72
I have a 69 GMC and i want to use a slop nose hood instead.
I was told that I could use a 67 or 68 hood on it with no problem since its a GMC. It appears to have a 67 fender on it right now. Can anyone tell me if this is true and what my options are? Thanks.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
Old Skool Club
![]() Join Date: Jun 2001
Re: hood interchangeability 67 - 72
There are differences in Chevy and GMC, for sure. But, I don't think the hoods are interchangeable like you'd like to think. I'm with you, though. The style you like (67-68) was deemed "too feminine" by the GM design brass and that is where the change was made for the '69 models. Harry Bentley Bradley said all that in an interview that he did in a Classic Trucks or Custom Classic Trucks magazine, several years ago.
I know there are some details about the fenders that are addressed by the trim on the leading edge, but I saw another post last night where the poster had a '69-72 with a '68-69 hood. There was a gap at the rear of the hood, at the cowl, for one of the issues. You can pancake the later hood, and get lower slope (less vertical) and make it more like what you want. But, the amount of pancake you can achieve, is limited to what will still clear the radiator support....and those supports are different, too....early to late.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Lemme show you something!!
You CAN use the 67/68 hood with your '69 fenders! The issue being the grille. On 69 and later models the top "filler strip" was designed to match up with the upright profile of the hood. To use a slope-nose hood, you'll need to source the 67/68 top bar and rivet/bolt it on in place of the 69 version you have. From what I've seen, they aren't being reproduced so you'll probably have to scour the parts board here or your local-ish Craigslist to find what you need. Oh yeah, you'll also need the 67/68 hood latch too!
Happy hunting- with a little patience you should be able to get what you need. In fact there was a 68 GMC here in Portland that was being parted out. If you like I can see if the grille assembly is still available and try to snag that top bar if you like. PM me if interested. Below is a pic of the part that you need to find.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
Thanks guys thats exactly what I wanted to hear. Now I just gotta find a 67/68 hood here in northern CA.
![]() Im interested in the parts there in your neck of the woods. I'll pm you.
I agree with Dingfodgy.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Are the Chevy hoods different than the Gmc hoods? Could one do the same thing on a Chevy?
The hoods are the same, it is everything else that is different. To do this to a chevy is much more difficult than just changing the top bar on the grill.
72 Cheyenne Super 80 Silverado Blazer 2wd |
Try picknpull for a hood me and my dad went to the one on sunrise and there were 2 or 3 67-68s there then the picknpull on North Antelope Rd had another 2 or 3 I believe but I'm not sure if they're still there or not but just giving yah a point in the right direction.
1969 Chevy C10 Short Step -Project 2005 GMC Sierra Crew Cab 1500 -DD 2017 Laguna Orange Roadglide - Good Weather DD |
#9 | |
hey thanks! I guess I might have to take a drive out to Sac and see.
what on a chevy needs to be done to run the early hood?
Basically everything that was told to the GMC guy plus the fenders
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!! |
If you want a 69-72 chevy to have the look of a 67-68, you pretty much have to change the whole front end clip. Hood, fenders, core support, grill support/ hood latch.
72 Cheyenne Super 80 Silverado Blazer 2wd Last edited by sameyrasmea72; 09-02-2010 at 05:08 PM. |
#13 |
I am a Referee of life.
The best looking 67-68 sloped hood on a later truck I've ever seen was when the owner "pie cut" the original hood and laid the front back like the 67-68.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#14 |
id like to see what this looks like!
#15 |
Thats quite an undertaking.
#16 |
Check out the Lo-Buck build if I remember correctly he put a 67-68 hood on a 69-70 front clip. It is alot of work but it can be done.
#17 |
![]() Join Date: Jun 2010
So a 69 or 70GMC hood is the same as a 71 Chevy?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#18 |
69-72 hoods are all the same with the exception of the GMC letters on the hood.
#19 |
I'll check it out
![]() thanks!
#20 |
Im having a hard time finding it. Can you link it?
#21 |
#22 |
i have a 68 chevy....can i use the front chrome hood lip from the GMC?, i like the way this GMC hood lip looks....and i have the GMC front grill in my garage now.
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride ![]() ![]() 54 caddy 62 series 4 door(younger sons ride, aka 54caddy ![]() 70 caddy 2 door, 89 chevy silverado stepside(older sons rides ![]() |
#23 |
The truck with the laid back hood was in a mag 6-8 years ago.CCT or CT.It was a shot of a finished truck and i read the write up on it since i knew a 67-68 hood wouldn't fit with the later front end.It just described the way it was done.Wish I could find a pic but I haven't had any luck.
#24 |
PanelDeland I remeber that truck I think my dad has the mag. I'll go look for it and snap some pics if I find it.
#25 |
I have a 69 gmc that i put a 67-68 chevy hood on it. You just have to change the top grille bar . The hood latch , and support are the same.it looks great !! Good luck on your truck
