Old 09-01-2010, 03:01 PM   #1
1stchevy
1stchevy's Avatar
SD Wishbone
Is anyone running the Suicide Doors rear wishbone super lift system?
1stchevy is offline   Reply With Quote
Old 09-01-2010, 03:59 PM   #2
blime81
Laid Lo
blime81's Avatar
Re: SD Wishbone
I love mine.
build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=415887
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 09-01-2010, 05:11 PM   #3
1stchevy
1stchevy's Avatar
Re: SD Wishbone
How much lift do you get out of that set up?
And thanks for your reply, that kit looks great.
Old 09-01-2010, 10:05 PM   #4
mac72
Re: SD Wishbone
I was messin' w/ mine today & I can tell you the shocks that come w/ the kit are 15" collapsed /23.5" ext. thats 8.5" of travel the driveline angles & the bags look good at any set point in that range.If you need any measurements let me know my chassis doesnt have the body on it so it wont be a problem.My setup is SD front & rear & the quality is flawless.Hope this helps
Mac
mac72 is offline   Reply With Quote
Old 09-01-2010, 11:55 PM   #5
blime81
Laid Lo
blime81's Avatar
Re: SD Wishbone
Mac72 is right, I am only limited on lift by the shocks. It will actually get the truck as high as factory leafs w/ overload with longer shocks. But the KYBs that come with it are great (and what I run). Plenty of clearance when aired all the way up. I think it is a very well engineered setup. The ride is very nice.
The welds on these kits are amazing and the fit is great. Pinion angle is easy to set and adjustable with the threaded ends.
Install was straightforward. Didn't need much more than a welder (for the notches), magnetic angle finder, grinder, drill (get a GOOD 1/2" bit as there are quite a few holes), sawzall or cutoff and basic hand tools (I wouldn't wanna do it without air tools but you could). Really the most time consuming thing was removing all the factory rivets.
One thing to keep in mind is that SD seems to make them as they go. You don't order and see it in a couple days. I was on a time crunch to get mine and they worked with me but these things are made to order. When I called about it they knew what stage it was in and each part was marked with my order # when I received it. Took about a month but good things come to those who wait!
Semper Fi,
Jeff
Old 09-02-2010, 12:47 AM   #6
1stchevy
1stchevy's Avatar
Re: SD Wishbone
thanks guys for all the help. i know SD and Porterbuilt are both quality companies but i know a lot of people are using PB stuff on here and i was curious how the SD stuff was.
