![]() Join Date: Nov 2009
Pinion Angle
Hey guys, does 5 degrees of pinion angle sound correct? I did some math and figuring and that is what i have come up with. I cannot check it because i have no motor or tranny in my truck at the moment. Just wanting to confirm this before i weld the axle perches in place.
Re: Pinion Angle
Three to five degrees down depending on what angle your transmission is at bolted in....
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Re: Pinion Angle
always set all my hot rods between 3 and 5 degrees and never a problem. Can't remember where i got the info, but it was years ago. Craftsman makes a nice magnetic angle finder and it's fairly cheap. In fact just changed my old truck to a 350 auto this last week, had to build a crossmember, set it a 3 degrees.
www.picturetrail.com/skysoldier173rd Last edited by skysoldier173rd; 09-01-2010 at 08:57 PM. |
Re: Pinion Angle
3 to 5 degrees down??? Wouldn't the pinion be 3 to 5 degrees up?
Re: Pinion Angle
Yes 3 to 5 degrees down when compared to the drive shaft which should also be 3 to 5 degrees down from the transmission. I had often heard that the angle of the transmission yoke should be the same as the angle as the pinion yoke.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Pinion Angle
You know what Zack, I need to appologize. I gave you some bogus info in your other thread regarding the pinion angle. I said that the pinion was 14 degrees up from the trailing arm mounts. Well, that was actually 4 degrees up from the trailing arm mounts. Only explanation is apparently I had my head somewhere it didn't belong at the time......
Re: Pinion Angle
I heard the same as GENIII above in his post, that the pinion angles offset with equal angle, only one up and one down about the same amount (3 to 5 degrees). I have seen shims used also to obtain the proper angle on trans mounts if the crossmember comes out too low to bring it up.
#8 | |
Re: Pinion Angle
Senior Car Nut
![]() Join Date: Jan 2008
Re: Pinion Angle
see page 5 for rules on angles:
http://www2.dana.com/pdf/J3311-1-HVTSS.PDF basically, as mentioned above, the angle of the transmission and the angle of the pinion should be as close to equal (but opposite) AND there should be some angle at the u-joints
Larry |
Re: Pinion Angle
I guess the best way to do this is, level the perches and set the angle from that point???[/QUOTE]
Yes. I personally have shims and spacers all over my driveline and although it works great (no vibrations), to me it's kinda jalopy style and I wish that my perches had been welded in the right place from the start.
Re: Pinion Angle
Thanks guys. I will review this info and go from there.
Re: Pinion Angle
Just to clear up any possible misunderstanding, the pinion shaft should be PARALLEL to the transmission output shaft. You can call them opposite angles if you want to, but relative to true horizontal, the angle is the same (and the same direction) on both.
Ray |
#13 |
60-66 Nut
Re: Pinion Angle
That's what I did with the original rear end I checked. I leveled the trailing arm mounts and measured the angle on the pinion yoke which was 86.4* Allowing for a little error, I would figure 86*......or up 4* from level.
#14 |
Re: Pinion Angle
Having the pinion and trans parallel made a pretty bad vibration that I had go away. Definitely a better way of putting it!
#15 | |
Senior Car Nut
Re: Pinion Angle
Larry |
#16 | |
Re: Pinion Angle
Next question: The rear i am using is out of a 86 donor truck. I do not have the drive shaft from that truck. I only have my original driveshaft. My OE shaft u-joint cups are a good bit smaller than that of the 86. What is the solution to this? Thanks, |
#17 | |
Re: Pinion Angle
Now take the dimension info to your friendly local parts store and hope for the best. When you get that "deer in the headlights" look, head for a driveshaft shop. The driveshaft shop will charge you more, but at least will know what you are talking about. Ray |
#18 |
Re: Pinion Angle
Awesome! Thanks guys for all your help. I guess i have never seen a transition u-joint, LOL.
#19 |
Re: Pinion Angle
conversion joint is another term for it. any of the ujoint manufacturers should have a conversion list
ron |
