Old 09-01-2010, 05:39 PM   #1
Jobe72
Jobe72's Avatar
Replaced window felts/rubber...now hard to roll up
I recently replaced the felt and rubber on the main windows in my 72 GMC
Now it is really difficult to roll up my windows. It seems the felt channel is pinched where it goes from the window frame into the main door assembly.
Any thoughts or tips? Thanks.
1972 GMC Sierra LWB (Aquafresh)
1962 Cadillac Convertible
1962 Cadillac Sedan project
Jobe72 is offline   Reply With Quote
Old 09-01-2010, 06:06 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: Replaced window felts/rubber...now hard to roll up
I had to spray mine down every so often with silicon spray to make it work.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-01-2010, 06:19 PM   #3
gkesseru
gkesseru's Avatar
I spayed right into the rubber track with Armor All and it got a lot easier
72 Fleet (died)
78 Step (sold)
55 Step named Fred (sold)
00 F150
68 Step (named El Scorcho by PO)
Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932
gkesseru is offline   Reply With Quote
Old 09-01-2010, 06:26 PM   #4
OARNGESI
OARNGESI's Avatar
I had this problem the window chanel in the driverside door didnt go completely in and it made the window hard to go up and dowm
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 09-01-2010, 07:46 PM   #5
JimKshortstep4x4
I had a problem with the outside window seals, (the rubber parts). I installed the deluxe seals with the chrome beading and the rubber is very thick and stiff.
I ended up trimming the rubber back to fix the problem.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-01-2010, 08:28 PM   #6
Jobe72
Jobe72's Avatar
Yes I installed the deluxe ones as well. I'll try some lube before I start trimming.
Thanks for the help
Old 04-22-2014, 02:25 AM   #7
jondancer
I also hAd this happen, where do you spray the lube?
jondancer is offline   Reply With Quote
Old 04-29-2014, 10:57 PM   #8
74baggedbug
I just replaced my glass and having the same problem now .. I'll try the armorall before I start trimming
74baggedbug is offline   Reply With Quote
Old 04-30-2014, 12:05 AM   #9
jeffahart
jeffahart's Avatar
You really need to cram the felt in that channel transition good and not use a straight line at transition but make it sort of step at the transition. Also make sure the wind wing is fully seated loosen the screws and press it up and over. I had some trouble with my wind wing not all the way seated too and it put pressure on the opposing channel. All those little things add up.
jeffahart is offline   Reply With Quote
