Old 09-01-2010, 08:41 PM   #1
67gmcstepside
How too mount the alt brackets to the exhaust
Just received these from southern parts from his parted 68 V8. I can't figure out how the angled bracket mounts to the exhaust thread boss's. It just doesn't seem to fit in any why I try. I assumed 67/68 were the same and mounted the same. Most pics I find the alt is covereing up the lower bracket. Any insight would be apprecated. Many I have the wrong ones but Southern did say they mounted to the exhaust :-( I know I will feel stupid if they really do fit and I just couldn't figure it out.
67gmcstepside is offline   Reply With Quote
Old 09-01-2010, 08:57 PM   #2
Indyuke
Re: How too mount the alt brackets to the exhaust
Does your exhaust look like this one?
Indyuke is offline   Reply With Quote
Old 09-01-2010, 09:09 PM   #3
vectorit
What?
vectorit's Avatar
Here is how mine are.
1968 truck ram exhaust manifold.
The lower bracket you have is what I have, but those uppers you may have trouble with (Not enough arch). Check my last pic.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-01-2010, 09:39 PM   #4
67gmcstepside
Indyuke, yes my exhaust looks like yours. My brackets look nothing like the one attached to your manifold. Maybe I have the wrong one.
Old 09-01-2010, 09:40 PM   #5
67gmcstepside
victorit, so the long piece goes under the top mount. Let me see if that works. out to the garage I go,
Old 09-01-2010, 09:49 PM   #6
67gmcstepside
Looks like I have the wrong set. Indyuke, is that exhaust/bracket off a 67?
Old 09-02-2010, 09:43 AM   #7
turp mcspray
turp mcspray's Avatar
Looks like the upper style that you have, are the ones that bolt to the intake. They often stack 2 together, to make them more rigid. Give that a try.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 09-02-2010, 10:53 AM   #8
DPowers
DPowers's Avatar
I believe the brackets you have are not used for the exhaust manifold that Indyuke posted. They use a different type manifold boss.
DPowers is offline   Reply With Quote
Old 09-02-2010, 11:15 AM   #9
67gmcstepside
So my next question is are the manifolds with the threads pointing out correct for a 67 or are the ones pointing forward? If I understand which manifold is correct I can find that years alt brackets. Thanks for aLL THE HELP SO FAR guys!!!!
Old 09-02-2010, 01:16 PM   #10
Indyuke
I was under the impression that what DPowers and Vectorit has was used for the 67-68 283 and 327 are correct... take a look at this site: http://www.am-autoparts.com/AM/Exhau...-/AM-28014528/
The style I have was used more often in the early to mid-60's trucks and in most corvettes. If you have the same setup I have, then you should only need the angled pieces to secure the top of the alt. by bolting it to the intake manifold like DPowers last pic shows.
Can you post a pic of the exhaust manifold that's on the truck?
Old 09-02-2010, 01:46 PM   #11
67gmcstepside
Its the same as what Indyuke posted. Thanks for your time, I apprecate.
Old 09-02-2010, 10:34 PM   #12
DPowers
DPowers's Avatar
My pic was from my '66
