![]() Join Date: Nov 2005
Anything worth taking off this PIG?
I'm keeping the front seats the engine and transmission, anything else worth pulling.
We plan on shooting the body up with holes this weekend. Thanks, Thomas
Soon to be selling all but one, or two... Depends on what the Boss has to say....... 67 GMC Shortbed 454 Project more junk and most of it is for sale |
Old member
Get the outside mirror's. What rear end does it have?
Does it have front disc? ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Anything worth taking off this PIG?
more pics might pull column too
That tire on the inside look like a good one!
#5 | |
I've also been told the front cross member is not the same dimensions as these had a wider track... Dont know for sure if thats true if so would the rear end have a wider track also than our trucks?
TIres holding air will be kept, those that are flat will go with it to the scrap yard. I'll fill the inside with other misc parts and junk from the farm for weight too.
6>8 Plugless........
![]() Join Date: Sep 2007
Are these all parts vehicles? Would you want to sell some parts off that red ford next to it?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#8 | |
What do you need perhaps the black one has it? I have another red one I drive and my dad has a blue Ford truck so it really depends on what you are looking for but I may be able to help.
![]() Join Date: Jul 2010
Looks like many good parts...look usable...I don't have a use but I am sure someone would be interested maybe do a parts for sale post...
Im going to have a very small window of opportunity to remove anyting and could not promise anything because of this. Engine and trans take priority. Seriously this thing is destined to be shot to pieces with SKS's, 9MM, 40, 30 carbine, 22, and shotguns this weekend. I have Friday afternoon and possibly Saturday AM before the exicution.
Not intended as a sales add but as one that I was looking for ideas of items that may have value that I don't see. Arm rests door and window handles. ??? Not sure about the rear seats I think they must have come from a school bus.
Soon to be selling all but one, or two... Depends on what the Boss has to say....... 67 GMC Shortbed 454 Project more junk and most of it is for sale Last edited by 67Mach1; 09-01-2010 at 11:32 PM. |
#11 | |
"THE GREEN GOBLIN"
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
![]() Join Date: Apr 2005
The rear tag bracket is the same as the one for 67-72 trucks.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#13 |
headlight trim wiper arms carb and aircleaner pulleys accessory mounts dipsticks washer resevoir overflow tank gascaps oilfill caps seatbeltsand anchors sunvisors wiper switch(if with delay??) vent window handles any knobs
#14 |
![]() Join Date: Oct 2001
Check and see if it has a swaybar setup on the front also!
Things happen for a reason! |
#15 |
THaks for all the great ideas, I'll try to get off as much as I can. Cutting torch in one hand impact wrench in the other.
SO far Engine and transmission with all accessories Front seats and seatbelts Column door mirror, arm rest, and interior handles,cranks Rear plate bracket Tires wipers headlight surrounds Possible front swaybar headlights side marker lights Im even gong to pull the gas tank as teh scrap yard wont take it with it in it and it might work on my sub? Oh, and a VIdeo of the fun!
Soon to be selling all but one, or two... Depends on what the Boss has to say....... 67 GMC Shortbed 454 Project more junk and most of it is for sale Last edited by 67Mach1; 09-02-2010 at 08:06 AM. |
#16 |
the side markers lenses they bolt right on our trucks.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#17 |
Factory Strippers Rule!
![]() Join Date: Mar 2009
I've been looking for one of those vans... I think a windowed shorty would look kinda cool all done. At least put a Ford emblem on it so it will want to be put out of it's misery.
R.I.P. Creepy Molesto Van ![]()
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
#18 |
At least get the steering wheel.
72 Cheyenne Super 80 Silverado Blazer 2wd |
#19 |
Redefining LowBudget
and I'm intersted in the Brake booster
do the bumpers fit our truck they look straight?? |
#20 |
I'd be interested in all 4 steel wheels if they are straight ...
#21 | |
#22 |
check the rear for posi...it has a 12 bolt in it..same as trucks.
radiator hold down brackets are the same also. P/S pump..and brackets are long water pump. |
#23 |
Like was said before, the steering wheel looks good.
#24 |
Has more rust than truck...
AM/FM radio? Big money...to me anyway
#25 |
