Old 09-02-2010, 07:47 AM   #1
Patsfan34
Patsfan34's Avatar
Secondary throttle body linkage on 87 GMC 4x4?
There's the gas pedal linkage and then on the end a secondary linkage that is held on by a snap ring. This second linkage was disconnected and just laying on the side on the throttle body. When I push the linkage toward the firewall I makes some rush of air/vacuum noise. I assume this was disconnected on purpose because the snap ring was still on the linkage. What exactly is this for and should I reconnect this linkage.
Also, there's a little foil heat riser that goes from the top of the passenger side manifold to the bottom of the air cleaner. This was also not connected and just sitting on the inner fender well. Is this something I need to reconnect or can I leave it disconnected because it really serves no purpose?
Thanks in advance!
Patsfan34 is offline   Reply With Quote
Old 09-02-2010, 08:22 AM   #2
Sarge261
Sarge261's Avatar
Re: Secondary throttle body linkage on 87 GMC 4x4?
The secondary linkage is most likely for the cruise control if you have it. If not maybe he had a air compressor or something installed, but I am thinking cruise control.
The foil tube is for the TBI, for cold weather its supposed to help heat things up. Most are torn or disconnected anyway.
I still have to get your pictures but I'll get them for ya.
Sarge
1997 GMC Yukon
Western Mid Weight Plow
Project THOR
Sarge261 is offline   Reply With Quote
Old 09-02-2010, 10:05 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
might look like this
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
