Old 09-02-2010, 07:55 AM   #1
Devins-step
Will C-20 body parts work on a C-10?
I have found a good deal on a 1971 C-20. I am thinking about buying it for parts. Can anyone tell me if the doors etc will fit on my 1970 C-10 truck or maybe even the entire cab? (the cab of my C-10 is being held together with spit and bailing wire!)
Devins-step is offline   Reply With Quote
Old 09-02-2010, 08:08 AM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Will C-20 body parts work on a C-10?
Yes
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-02-2010, 08:18 AM   #3
Devins-step
Shyguy. Thanks for the quick response. One other thought has come to mind. I have a short wheel base stepside bed in good condition (1967) I have heard of guys cutting down the frames and making short wheel base trucks out of long wheel base. Any thoughts?
Old 09-02-2010, 08:31 AM   #4
raisinracer
Not a problem ,as long as you take your time to keep it all square, can weld and have a good welder.There a few threads and articles about it step by step.
raisinracer is offline   Reply With Quote
Old 09-02-2010, 09:47 PM   #5
leddzepp
Moderator
leddzepp's Avatar
I am in the process of converting a C/20 to a SWB fleetside, all sheetmetal interchanges. It is the only way to go IMO.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 09-03-2010, 08:03 AM   #6
Shyguy
Junior Member
Shyguy's Avatar
I bought a '67 C-20 lwb stepper along with a '69 swb frame from one of my grandsons. We swapped all the sheet metal over to the swb frame without a problem, well there was one.
We used the 3/4 ton cab mount bushings on the swb frame. We could not get the right gap/alignment between the front clip and cab. After a little research we found out that the rear cab mount bushings on a 3/4 are thicker than 1/2 ton.
