Old 09-02-2010, 02:16 PM   #1
67chevy2wd
67chevy2wd's Avatar
Anyone running the ORD twin stick for the NP205?
I was looking at the ORD twin stick for the NP 205 in my 71 GMC since the shifter linkage is shot and it doesn't always go into gear. How do the shifters line up with the factory hole in the floor? Is it a nice solid design?
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 09-02-2010, 07:53 PM   #2
70 beast
Certified Hobbiest
70 beast's Avatar
Re: Anyone running the ORD twin stick for the NP205?
what do you mean by shot?
a buddy of mine twin sticked his 205 using 2 shift levers (205 lever and a fabbed lever) and a longer bolt. im not 100% sure what he did as far as connecting the levers to the shift rails but i think he used the original connections just modded a bit.
heres a pic
and how they came through the floor
but if thats too much work then offroad design is a great company with awesome products
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 09-03-2010, 04:10 PM   #3
67chevy2wd
67chevy2wd's Avatar
edit: double post
'71 GMC 3/4 ton 4x4
Old 09-03-2010, 06:24 PM   #4
67chevy2wd
67chevy2wd's Avatar
That looks good. My bushings and linkage are worn out so my stock lever flops all over. If I could buy new bushings I would probably go the route your friend did.
'71 GMC 3/4 ton 4x4
