Old 09-02-2010, 03:58 PM   #1
qu1cks1lver56
qu1cks1lver56's Avatar
88-95 alternator type?
Is the alternator on the 88-95 half tons a CS 130 or a CS 144, and are they the same case?
qu1cks1lver56 is offline   Reply With Quote
Old 09-02-2010, 10:19 PM   #2
ChevyTech
Re: 88-95 alternator type?
Between 1988 and 1995 there are many different alternators on these trucks. It depends on the equipment package / how many accessories the vehicle has as to which alternator is used on it. They are not al the same size and some are mounted differently.
Use the RPO code in the glove box to identify which alternator it has.
Old 09-02-2010, 10:29 PM   #3
ChevyTech
Here are some RPO codes:
K60 - GENERATOR 100 AMP
K61 - GENERATOR 105 AMP, DUAL INTERNAL FAN, ENHANCED IDLE OUTPUT
K62 - GENERATOR 105 AMP, DUAL INTERNAL FAN
K63 - GENERATOR 110 AMP
K64 - GENERATOR 115 AMP
K65 - GENERATOR 105 AMP, DUAL
K76 - GENERATOR 61 AMP
K77 - GENERATOR 56 AMP
K79 - GENERATOR 42 AMP
K81 - GENERATOR 66 AMP
K82 - GENERATOR 75 AMP
K83 - GENERATOR 35 AMP
K85 - GENERATOR 37 AMP
K88 - GENERATOR 45 AMP
K89 - GENERATOR 50 AMP
K90 - GENERATOR 108 AMP
K91 - GENERATOR 65 AMP
K93 - GENERATOR 32 AMP
K96 - GENERATOR 55 AMP, BUILT-IN REGULATOR
K97 - GENERATOR 80 AMP, BUILT-IN REGULATOR
K98 - GENERATOR 140 AMP, 57MM PULLEY
K99 - GENERATOR 85 AMP
KG0 - GENERATOR 74 AMP
KG2 - GENERATOR 60 AMP
KG3 - GENERATOR 145 AMP
KG4 - GENERATOR 150 AMP
KG5 - GENERATOR 150 AMP, 57MM PULLEY
KG6 - GENERATOR 96 AMP
KG7 - GENERATOR 125 AMP
KG8 - GENERATOR 130 AMP
KG9 - GENERATOR 140 AMP
KW1 - GENERATOR 160 AMP
KW2 - GENERATOR 124 AMP
KW3 - GENERATOR 135 AMP
KW7 - GENERATOR 170 AMP
KW9 - GENERATOR 190 AMP
KXB - GENERATOR 100 AMP, DUAL
KYU - GENERATOR 200 AMP
Old 09-04-2010, 11:43 AM   #4
qu1cks1lver56
Cool, thanks.
Old 03-07-2025, 07:40 PM   #5
ballencd
Unhappy Re: 88-95 alternator type?
I'm confused on this as well. The RPO code tells you the amperage of the alternator but does not tell you the model of the alternator. I have a 1991 Suburban V1500 with a 5.7 TBI engine. I have the RPO code of K60 (100 amp) but is it the CS130 or CS144....????
1983 M35 (bobbed and converted to dump)
1984 M1010
1988 Chevy Suburban (5.7TBI/TH700R4/NP208)
1991 Chevy Suburban (5.7TBI/TH700R4/NP241C)
ballencd is offline   Reply With Quote
Old 03-07-2025, 07:49 PM   #6
Grounded63
Just look at the case they are distinctly different.
Grounded63 is offline   Reply With Quote
Old 03-08-2025, 02:37 PM   #7
ballencd
Will either of the two fit a 1991 Suburban with a 5.7 engine....???
1984 M1010
Old 03-08-2025, 04:12 PM   #8
Grounded63
With some minor modification, either one will fit.
Old 03-12-2025, 10:27 PM   #9
Mr_Rich
Mr_Rich's Avatar
To mount the CS144 in the CS130 mount you need the bracket that cradles the CS144 alt in the CS130 mounting space. I have this on my '89.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 03-13-2025, 08:45 AM   #10
ballencd
Anyone have a picture of said mount? Is this something I can fabricate or purchase?
1984 M1010
