Tilt Colum parts on a non-tilt
Ok, I have an Auto tilt column, and I have a 4 speed truck. If I get a 4 speed column, can I swap the tilt parts over to it from the auto column? Thanks.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
member #16
![]() Join Date: Dec 1999
Re: Tilt Colum parts on a non-tilt
I dont think so. They are constructed completly differently.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
4speed manual columns have no shift parts as the shifts for 4spd manual trannys are all on the floor
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 09-02-2010 at 05:22 PM. |
#4 | |
Old member
![]() Quote:
If you want the tilt to look like a factory tilt for a 4 speed yes all you need is the manual cover for the tilt area. This will do away with the gear shift opening and if I remember right it will slip right on the auto, if this is what you are looking to do. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#5 | |
TILT COLUMN GURU
![]() Join Date: Dec 2006
You will have to shave and fill your tilt column.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
Old member
Sorry,
I thought I had read you could use the column and just buy the manual cover for it someplace on here. Kevin can you give me a price on new parts for mine. It's a orignal 4 speed manual but needs to be tightened up some. Bearings and such. The tilt is a little loose to. ![]()
