![]() Join Date: Feb 2008
86' x-member under 68' chassis
I found a 86' 2wd x-member to go under my 68' chassis. I have a set of 72' upper and lower control arms. Will they work with the 86' x-member or should I find the a set of 86' arms?
Re: 86' x-member under 68' chassis
They'll work. Why the swap to the 86 x-member for your 68 chassis?
My plans for the truck over the winter are, converting it to 5 bolt, back half it and bag it. I read somewhere that the 72' arms and drop spindles wont work with my 68' x-member. Heard it was easier to just swap in the 73'-87' x-member.
#4 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
(just a different upper and lower ball joint) So you could actually use your '68 a-arms, (with a ball joint change),... unless they are wore out and the '72 arms are rebuilt. The 73-87 a-arms are rubber bushed on the cross shafts. The 67-72 a-arms have steel bushings. The crossmember itself doesn't need to be swapped out. Just make sure the balljoints and tie rods match whichever year of drop spindles you buy. Buying 67-70 disc brake conversion spindles will allow you to use 68 balljoints and tie rods,... which you already have.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 09-02-2010 at 06:24 PM. |
#5 | |
#6 | |
Now "IF" I was to use the 86' x-member, would the 72' drop spindles work with the 86' arms? Or should I just save a hastle and use my 72' arms on my existing x-member. There was another reason I was searching for a new x-member but can't remember why. I'll have to inspect it again. |
#7 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-02-2010 at 06:36 PM. |
Thanks for all the info guys!
I guess there is no real point in getting the other x-member than. |
Happy to be here
![]() Join Date: Mar 2000
The only advantage would be to clean, paint, update, as a complete assembly before you tear your truck down.
My existing x-member is coming out anyways so I can clean up the frame and send it to a buddys shop to have the back half measured up and put in. I'll probably just buy new a arm shafts and rebuild my 72' arms.
I will be using the same engine/trans combo that came out. Only differance is the stroker kit.
