Old 09-02-2010, 08:13 PM   #1
Oilbrnr
Oilbrnr's Avatar
Engine delima - advice sought
Here's the situation; I've got a '77 K5 that I got from the original owner going on three years ago. Sands Chevrolet here in Phoenix put a GoodWrench long block in it in '97. It has about 30k on it, and is consuming oil at a growing rate via the valve guides.
I have a 2007 Silverado 4.8l LSx that needs the alt/ps alum. bracket and and alt/pump. (came from a major driver side wreck, I'm assuming...) Downside, I'm worried that it would strong enough for the K5. Yeah on paper it is very comparable to the old 5.7, but... Also, I'd need to get all the other parts to get it installed, including figuring out what flywheel/clutch combo will work.
Then again, I could try and pick up a decent 454 in running shape and drop it in.
I'm running the stock 3.73 gears and 33's, and it was/will be my DD during the work week. (trying to save the Duramax!)
So rebuild the 350, do the LS swap (with a small V8) or go 454?
-Don-
'66 C10 w/factory A/C
'77 Cheyenne K5 350/465/205
'80 Custom Deluxe K20 350/465/205
'04 Denali XL
'05 DMax CCLB 4x
Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf
Oilbrnr is offline   Reply With Quote
Old 09-02-2010, 08:33 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Engine delima - advice sought
Do the LS swap. You will be beyond suprised with that 4.8 For daily driving the 4.8 is a great engine and will do everything you ask of it besides pulling a loaded car trailer really quick. With no emissions and a tune it will put down PLENTY of power for ya!
--Josh
Old 09-02-2010, 08:36 PM   #3
PRattenbury
I guess you have to weigh the cost of installing the 4.8 against the benefit you would have over freshening up the heads on your existing engine. That's what I would do, but I'm a cheap, lazy bastage.
PRattenbury is offline   Reply With Quote
Old 09-02-2010, 09:52 PM   #4
Oilbrnr
Oilbrnr's Avatar
Well, me thinks that it also needs some bottom end attention too. If I'm yank'n it, it would get a *decent* rebuild.
72SC, I'm leaning back towards the LS swap. You are not the first to state that the 4.8 with the right tune, is a decent mill. Hope the SM465 is ready for that kinda power!
Look for *Project Peanut Power" in the build section soon.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 09-03-2010, 10:48 AM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
The 4.8 will do fine, I have one in my 65 and as far as power and such, it is lots better than my 350, it gets 20+ MPG on the highway and averages 14.5 in mixed traffic, it also has plenty of power to break the tires loose when I want to show off.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-03-2010, 12:30 PM   #6
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
The 4.8 will be night and day difference from the 350. The question of using the 4.8 wouldn't even pass through my mind, I would just be doing it!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-03-2010, 01:43 PM   #7
Oilbrnr
Oilbrnr's Avatar
Well if Bob says to do it, then I guess I better get busy!! Labor day weekend may be spent getting the shop ready to start pull'n the K5 apart.
What is the best way to pick up some of the missing front accessories that I need for the 4.8L? Local junkyards or posting in classifieds here and on LS forums?
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 09-03-2010, 01:48 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
Things to consider:
*Fuel pump---unless you put on a carb, the fuel pump will have to be electric
*different exhaust, it should clear, but may not
*different motor mounts
* do you get the WHOLE engine---accessories and all
*4.8 truck engine, then the accessories should be in the right place for your truck
*tranny connection--does the new tranny connect to your drivetrain--will oyu have to make a new driveline or spline adapters
*computer setup, are you ready for that type of project
*Do you have the time to install a complete engine and do the extra stuff
Frank
piecesparts is offline   Reply With Quote
Old 09-03-2010, 02:04 PM   #9
Oilbrnr
Oilbrnr's Avatar
Thanks, but I'm aware of what is involved. I've just been sitting on the fence for too long.
I'm missing the alternator, PS pump, bracket that they mount to, and the DBW pedal (and maybe module that it connects to). Otherwise it is complete AFAIK. Oh and the DS exhaust manifold is gone.
It is a truck motor, and I'll be mounting it to a SM465, so the engine mounts will need to be *flexible* in their adjustments somewhat, as I'm not relocating the rest of the drivetrain!
I've got a big shop, esp. if I pull out the toys, and I do have a two post lift. So the major limitation will be, as usual, $$$.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
Old 09-03-2010, 04:19 PM   #10
piecesparts
Keep in mind that your old tranny does not need a lot of the stuff that the newer ones have. So the computer could have the stuff in it to shift the tranny and if it is used with an older style tranny, then you have a computer code to eliminate. A good hacker can do that, but you have to find one.
Frank
Old 09-03-2010, 04:34 PM   #11
Oilbrnr
Oilbrnr's Avatar
Yeah, I'm pretty sure the SM465 only needs a backup light wire. Even that is negotiable.
OTOH if you mean that the tune has to eliminated the need from feedback from the transmission (auto) then that is a different story. I don't think it does though, other than some sort of accurate speed input. I plan on using a Cable X.
-Don-
'04 Denali XL
'05 DMax CCLB 4x
