Old 09-02-2010, 10:40 PM   #1
idaho66stepside
idaho66stepside's Avatar
Talking Stripping
What is your guys perferred way to strip paint? Chemicals or sanding. Thanks guys
idaho66stepside is offline   Reply With Quote
Old 09-02-2010, 11:15 PM   #2
GGinferno
DiablosWeldingFabrication
GGinferno's Avatar
Re: Stripping
It depends on what im doing? but if i really need to get down and dirty i like using Jasco! this stuff is good! but be carefull son of ***** burns like hell when it falls on your skin!
GGinferno is offline   Reply With Quote
Old 09-03-2010, 12:45 AM   #3
Captainfab
60-66 Nut
Re: Stripping
I prefer abrasive media blasting. Of course I'm lucky in that I have a friend that does that for a living. But it is still the best way to strip paint and remove rust IMO. The chemical remover will take the bulk of the paint, and you can then sand the rest off. It sometimes takes 2 or 3 applications of the remover to get all the paint off. The heat from the sun will help too. And wear some good rubber gloves too. Like GGinferno said...it burns like a sum-b.
Old 09-03-2010, 12:49 AM   #4
sams60gmc
sams60gmc's Avatar
Re: Stripping
Aircraft stripper seems to work good.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
