Old 09-03-2010, 04:06 AM   #1
eat1sleep8blink2
eat1sleep8blink2's Avatar
replacing wing window
i have a 87 suburban and need to know how to properly relpace a wing window in it looks the same as the trucks
I dont have a girlfriend, I have a dog. mark from blink-182
eat1sleep8blink2 is offline   Reply With Quote
Old 09-03-2010, 07:21 AM   #2
ECU PIRATE
ECU PIRATE's Avatar
Re: replacing wing window
It is. I have taken several out. You have a couple of screws to remove in the door jamb and a few bolts to undo under the door panel. You should be able to pull it right out after that
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 09-03-2010, 07:38 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
i think i took out the big window first dosn't the track for that connect to the little window and a bolt to the mirror support ,i got loose ones at home i'll post a pic
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 09-03-2010, 02:16 PM   #4
HOGDADDY
HOGDADDY's Avatar
Yes there is a track (division track as it is often called) that the large window slides in at front.
I think you can just loosen the rear door glass channel and move it over enough to get the vent window out.
Also the screws in the door jamb are sometimes difficult to remove. Best to use an impact screw driver or do like I did and use a hammer........
If you hit the screwdriver with hammer and at same time turn it with hand (need a very firm grip) just dont miss and hit your hand or you could use channel locks to turn it maybe.
HOGDADDY is offline   Reply With Quote
Old 09-03-2010, 02:42 PM   #5
78 Chevyrado
Heres a pic of the top 3 screws
78 Chevyrado is offline   Reply With Quote
Old 09-03-2010, 03:45 PM   #6
eat1sleep8blink2
thanks for your help im going to the junk yard to find one now
